View Poll Results: Should I ditch my catback and y-pipe at the track?
Yes, the extra weigh loss will help.
2
66.67%
No, please explain why?
1
33.33%
Voters: 3. You may not vote on this poll
Should I ditch my catback and ory?
I'm heading to the track this weekend and I'm looking to ditch some extra weight. Should I ditch my catback and y-pipe to cut weight or will this hurt me on the low end?
This is what I did when I ran my new best of 10.61, I believe a good portion of the exhaust was still going through the catback over the cutout…I left the y pipe on the car…also it only takes like 5 minutes to remove when you make a cut at the top of the axle and bottom of the axle…use high temp hose and some band clamps, or even better weld some v band fitting and use v-band clamps to remove the section of pipe and then the cat back just slides right out the back…
