Drag Racing Tech
Recommend a 1330 / 1350 U-joint
Old 10-30-2009, 06:06 PM
rickou812's Avatar
Default Recommend a 1330 / 1350 U-joint
I need a 1330 to 1350 conversion U-joint. Prefer to get a solid (non grease-able) race type, but have been unable to find a solid conversion joint. DO these exist?
Thanks,
Rick
Old 10-30-2009, 08:42 PM
1CAMWNDR's Avatar
NAPA had the only 1330/1350 joint around hrere (Tallahassee); but it was not a solid joint. You just need to buy a Denny's 1350 driveshaft anyhow .
Old 10-31-2009, 12:45 AM
rickou812's Avatar
Whats up Mike?
I actually have a 4" dynotec 1350 shaft, but my 9" pinion is a 1330 . I wanted to run this weekend with the new shaft so I could use my transbrake. I guess I am going to have to wait until I can get a 1350 pinion yoke instead, or use a cheap greaseable conversion joint. It seems there is no such thing as a solid 1330/1350 joint, Oh well...
Old 11-01-2009, 04:21 PM
1CAMWNDR's Avatar
Bummer...............
Old 11-01-2009, 05:19 PM
98Camarod's Avatar
Did you find any 1330/1350 ujoint? My driveshaft is a 1330, but my 9" is a 1350. I'm the exact opposite as you
Old 11-01-2009, 05:25 PM
rickou812's Avatar
Nope, they only make geaseable 1330/1350, I decided to wait and get a 1350 pinion instead of running a conversion joint. But I also ran into bigger problems. My new 4" shaft will not clear my BMR torque arm
Old 11-01-2009, 05:26 PM
rickou812's Avatar
On a positive note, I did go a 1.41 60' today on the stock aluminum shaft without breaking it..lol
Old 11-01-2009, 05:29 PM
98Camarod's Avatar
Do you have the p/n on the conversion joint?
Old 11-01-2009, 05:37 PM
rickou812's Avatar
Spicer brand = DC5-648X
Napa = 447
Old 11-01-2009, 05:45 PM
98Camarod's Avatar
thanks!
Old 11-01-2009, 06:39 PM
WMSuperSport's Avatar
I have a solid 1350 in my Dennys driveshaft. It came with it. I also run the Moser billet pinion on my 12bolt.
Old 11-01-2009, 06:48 PM
rickou812's Avatar
Yep, solid 1350's are plentiful, what we need is a 1330/1350 conversion joint..
Old 11-01-2009, 09:30 PM
1CAMWNDR's Avatar
How long do you think it will be before you can get a 1350 pinoin? Congrats on the new quick 60ft.
Old 11-02-2009, 05:28 AM
rickou812's Avatar
Could have one this week, but the hold up now is modifying the torque arm to get the clearance I need.
I think what I am going to do is cut off the polyurethane front mount and change it to a heim joint and replace the shackle with a ladderbar type mount for improved adjustability. That should give the clearance I need..
Old 11-02-2009, 05:47 AM
Race your car!
JL ws-6's Avatar
You have to have a front mount that can move forward and backwards, you'd hve to refab the tq arm with a slider in order to put a heim joint in it.
You might be better off just ditching that tq arm and get a billingsley/madman/PAF arm if you want that type of connection at the front, those are the only 3 I know of that are made that way.
Old 11-02-2009, 11:21 AM
1CAMWNDR's Avatar
My Midwest Chassis torque arm has a heim front mount and works well. Even has a couple different holes in the front mount for adjustments.
Old 11-02-2009, 12:01 PM
rickou812's Avatar
Do you think a 4" shaft would clear on your car?
Old 11-02-2009, 12:08 PM
Race your car!
JL ws-6's Avatar
Madman piece does have a slider, it's inside the tube that's pictured, you can't tell from that picture, but it does.
Midwest also has one, I forgot about that one.
Old 11-27-2009, 09:16 PM
TJ
TJ's Avatar
lakewood use to offer a conversion joint that was solid.
Old 11-29-2009, 04:59 PM
1CAMWNDR's Avatar
I have no idea. Never thought I'd need one so I never measured. I am real happy with my Denny's Nitrous Ready shaft.
Quick Reply: Recommend a 1330 / 1350 U-joint
