Drag Racing Tech
Pictures of my winter Race car complete re-wiring project
Old 02-23-2010, 12:06 AM
SMKN TA 95's Avatar
Default Pictures of my winter Race car complete re-wiring project
This winter I decided I was going to delete some electrical items from my car and also add a few things, so I just ended up rewiring the whole car. A few months ago I wired another LS car, which gave me a few ideas to use on my car. I then took it a few steps farther and made a smaller, and more compact board. I also used some new relay centers that really tighten things up. The board is made of carbon fiber, for something different and because its light. I also made a new radio plate that houses a custom 5 switch panel for the nitrous control. I forgot to take pictures of that, but will here in the next day or two. This board will completely run the whole car, from the 2 stages of nitrous down to the parking lights. Everything is wired into here and uses metri-pak connectors for each separate harness that goes out in the car. Its basically a plug and play deal, once the harnesses are made.
I had some interest in the last board I made, and I've considered marketing this design. Basically a base design board with options added along the way. Would there even be an interest in such a thing?
On to the pictures......
Old 02-23-2010, 12:14 AM
2XR95Z28's Avatar
Wow, wanna wire up my s10? that looks amazing! very well done man...
wish i had the cash for you to make me a setup but dont think i do.
Old 02-23-2010, 12:17 AM
SMKN TA 95's Avatar
You might be surprised. I'm only a few hours away from ya. PM me if you have questions about the board.
Old 02-23-2010, 12:30 AM
airfix's Avatar
All I can say is WOW. Nice job dude.
Old 02-23-2010, 12:41 AM
flippincamaro's Avatar
Very sweet setup!!!!
Old 02-23-2010, 04:31 AM
Race your car!
JL ws-6's Avatar
That is a really nice setup for sure.
I'd actually like a wiring diagram for the whole car... shoot me a PM when you get a chance, easier that way.
Old 02-23-2010, 05:58 AM
White.Lightning's Avatar
If a schematic if floating around it could be hosted- definitely sticky material for all the drag race guys. I'm sure a lot more people would take on this type of project if some guidance was available.
Nice job!
Old 02-23-2010, 06:02 AM
Fireball's Avatar
very very nice
Old 02-23-2010, 06:21 AM
Race your car!
JL ws-6's Avatar
It would be a sticky if I can get one. I'd like to see how to wire the doors so you can ditch the body control module 100%, I'm ditching the power lock solenoids when I have the doors apart so I don't care if the fob works anymore. Same with the alarm, and I'm going to put a BS3 in with it's own harness, so that's done, just need one for the car, how to wire up the BS3 to it, and that's about it. I think I can figure the rest out, my setup is really simple, I'm just going to add a window switch to the nitrous engagement, and maybe wire in a progressor to get the 1 big kit to leave, and that's it.
Old 02-23-2010, 06:35 AM
Fireball's Avatar
I found a diagram (I think it was on turbomustangs) where it showed how to do power windows using two relays. You just need to "flip" the continuity electrically on a power window motor. wire it one way and it goes up. reverse it and it does down
***EDIT*** here's the diagram I found
http://www.theturboforums.com/smf/in...?topic=63983.0
Old 02-23-2010, 07:14 AM
Race your car!
JL ws-6's Avatar
Thanks fireball, that's a help for the windows. I want to put a set of switches in the wolfe door panels I'm gonna put in the car, 2 switches in the drivers side, drivers up and down, then a passenger's up and down.... seems like it won't be too bad.
Then I can ditch the entire body control box completely, just wire up what I want, should make things alot easier
Old 02-23-2010, 07:38 AM
BassProCamaro97's Avatar
Thats a slick setup. Nice work.
~Jim~
Old 02-23-2010, 10:04 AM
blk96406's Avatar
Very NICE!!!!! Hopefully someone can post up a schematic, this is where Im at now too.......
Old 02-23-2010, 10:15 AM
gator's 99TA's Avatar
looks like artwork (the entire in fact!)
Old 02-23-2010, 10:29 AM
sweetbmxrider's Avatar
that is insanely nice!
Old 02-23-2010, 10:36 AM
Skinny's Avatar
What's your source for the fuse panels? I've been trying to find something like that for a while now. That appears to be a seal around them; is there a weatherproof cover that goes over?
Old 02-23-2010, 04:08 PM
87Lt1Monte's Avatar
Very nice! what kind of wire did you use?
Old 02-23-2010, 05:56 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Very sweet. I dig it for sure.
Coach
Old 02-23-2010, 06:10 PM
SScam68's Avatar
what's the P/N on the relay banks?
damn that's nice
Old 02-23-2010, 06:33 PM
AChotrod's Avatar
Looks confuzing as hell. Great job!!
Quick Reply: Pictures of my winter Race car complete re-wiring project
