Drag Racing Tech
Would you run a radial for bracket racing?
Old 03-05-2010, 02:16 PM
87Lt1Monte's Avatar
Default Would you run a radial for bracket racing?
Im not sure if i should use a 28 x 10.5 S or something similar or a 315/60/15.. im minitub'd so i can use a fairly large tire.. what do you guys think?
Old 03-05-2010, 02:18 PM
Internet Mechanic
BlackScreaminMachine's Avatar
The biggest the car allows and also what the rules allow for.
Old 03-05-2010, 02:42 PM
tee-boy's Avatar
I'd put'em on an auto. They don't grow and side to side tire pressure differentials don't affect tire height to the extent of a bias tire. Just warm em up and run.
Old 03-05-2010, 02:48 PM
htownws6's Avatar
I've heard that bias ply is alittle more forgiving for a bad prepped track, and tend to be alittle more consistent. But I personally like radials better..
Old 03-05-2010, 02:49 PM
htownws6's Avatar
Oh, I misread the question. Yeah, stuff as much tire under there as you can.
Old 03-05-2010, 02:50 PM
tee-boy's Avatar
Default ddddd
bias tire is more forgiving
Old 03-05-2010, 02:55 PM
htownws6's Avatar
didn't I just say that?
Old 03-05-2010, 02:59 PM
7 Second Club
Phil99vette's Avatar
If the track is known to be good, yes. If your heading to a shithole throw the slicks on.
Old 03-05-2010, 07:45 PM
87Lt1Monte's Avatar
budscreek.. what ya think phil? Radials?
Old 03-05-2010, 08:52 PM
StreetSilverado's Avatar
Slicks will be more consistent at just about any track....over a radial IMO anyway. My 60's were 1.47-1.51 on a nice summer day with radials and with my 28x10.5's they were 1.43-1.44 all day.
Old 03-05-2010, 09:01 PM
gator's 99TA's Avatar
run a slick or a radial slick. if you are serious about braket racing, you put on the biggest slick you can find that will handle any track surface. bracket guys overtire cars and go rounds.
Radials are for ET/MPH records
Old 03-06-2010, 08:14 AM
87Lt1Monte's Avatar
Okay i was thinking about going with a slick as well.. Now i dont know what size to get.. these tubs can fit a 10.5w slick (so says wofles websiite) thats a fairly large tire..
Old 03-06-2010, 11:13 AM
htownws6's Avatar
What size rim do you have and what is your gear ratio?
Old 03-06-2010, 11:33 AM
6 & 8 Second Club
mrdragster1970's Avatar
As mentioned, consistency is more important. I would give up a little ET any day to be more consistent.
Stuff the biggest true slick you can in there and forget it.
Old 03-06-2010, 11:38 AM
7 Second Club
Damn right. Throw some 295s on it.
Old 03-06-2010, 12:01 PM
cbra-klla's Avatar
id look at what i would get the most wear out of....even though im a radial man!!
Old 03-06-2010, 04:46 PM
87Lt1Monte's Avatar
4.33 gears powerglide trans and 10" rim prolly make 650 to the wheels
Quick Reply: Would you run a radial for bracket racing?
