Drag Racing Tech
Spark plugs and nitrous??
Old 04-11-2010, 09:10 AM
2camaros6702's Avatar
Default Spark plugs and nitrous??
I know most everyone runs NGK TR6's when spraying and I just burnt up a few plugs at the track last night so I pulled one and it has Autolite 5245's in it. My question is are these plugs even used in the LS1 much less in a sprayed LS1 runnig low 10's??
Old 04-11-2010, 09:18 AM
02 BLK WS6's Avatar
You shouldn't be using nitrous if you don't even know what plugs are installed. Search in the nitrous section and you'll find your answer about what plugs you should be using.
Old 04-11-2010, 09:35 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Read the thread below
https://ls1tech.com/forums/nitrous-o...=projected+tip
Old 04-11-2010, 10:04 AM
NGK TR6's ARE what was suppose to be in the car or at least what I wanted put in the car. I know what is suppose to be in my car BUY that is not what was put in it so that in turn sparked my curiosity on the plugs that were put in it! NOW back to my original question how bad are the plugs that were put in it for my car?
Edited; I was a little harsh!!
Old 04-11-2010, 10:29 AM
Originally Posted by Z28/2002
Good read thank you for some good info.
Old 04-11-2010, 05:00 PM
Wicked94Z's Avatar
Originally Posted by 2camaros6702
NGK TR6's ARE what was suppose to be in the car or at least what I wanted put in the car. I am so tired of people on here that think they are so much ******* smarter than every one else I know what the **** is suppose to be in my car BUY that is not what was put in it so that in turn sparked my curiosity on the plugs that were put in it! NOW back to my original question how bad are the plugs that were put in it for my car?
its not that ****** hard, do a search on google. If you'd done that you'd see it crosses to a tr55. If you can't figure out if that's good or bad then you deserve what's coming to you.
Old 04-11-2010, 05:11 PM
505OUTLAWZWS6's Avatar
People are much smarter than you! They didnt put tr6's in there car and burn the plugs.
Old 04-11-2010, 06:25 PM
ATVracr's Avatar
Wow!
TR6's are not a good nitrous plug.
Old 04-11-2010, 07:47 PM
gator's 99TA's Avatar
greg, i know that you want opinions but i suggest a 7 plug for your application. its what i am running and what many other nitrous ls cars running the times you want to run suggest. good luck my friend. wish i could have been out at hte track to see it run, but wasnt able to head out there.
Old 04-11-2010, 08:09 PM
chknhwk01's Avatar
Talking Lets cccc
WHY A 7 OVER A 6..... AN WHAT A BOUT THES BADDD BOYS,,
AN HOW DO THEY MACTH UP, BR7EF PLUGS?????
WHAT U THINK PLAYER...
Old 04-11-2010, 08:27 PM
MetallicaMatt's Avatar
I've got TR6's ready for nitrous...should I have something different?
Old 04-11-2010, 08:32 PM
ATVracr's Avatar
How does positraction in a Plymouth work?
It just does !!
Old 04-11-2010, 08:37 PM
ATVracr's Avatar
For the record TR6's are projected tip plugs.
Read this ..........
https://ls1tech.com/forums/nitrous-o...tip-plugs.html
Old 04-11-2010, 08:48 PM
HuMi's Avatar
Well you arent too smart if you are trying to put some TR6's in a low 10 second car. Jokes on you tool!
Look at an Br8efs.
Old 04-11-2010, 09:41 PM
i remember asking a year or 2 ago what plug and was told the TR6 for a 150 wet shot.....so what SHOULD i run then?
Old 04-12-2010, 07:00 AM
This is a daily driven car I drive the car to work everyday and everywhere I go I put the TR6's in to get a little better driveability out of the car because my wife also drives it sometimes and I was trying to find a plug that would be right in the middle. I dont do most of the work on my car because I dont have to and sense day one I have been told with my setup to run TR6's. If I am wrong educate me dont just tell someone if they dont know they are stupid because I can guarantee there are many thing I can make many people look very stupid doing but chose not to.
I have no problem being wrong in using the TR6 plugs and if you have a reason or suggestion I will read it and learn a little more.
I went a little of the handle and realise it and I do apologize.
Old 04-12-2010, 08:11 AM
BAKED's Avatar
TR6's are projected tip plugs. They are not meant to be ran with nitrous PERIOD. Alot of internet racers on here will tell you that they are fine but they are not made to be ran with nitrous.
People do it all the time but those people have no clue what they are doing, they just read some **** on here and assumed it was the right thing to do.
Old 04-12-2010, 08:23 AM
HuMi's Avatar
I gave a very good plug for both NA driving (assuming your tuner can trim fuel trims correctly) and for spraying. using the correct plug NA usually nets a few more ponies as well with a good tune. Ive seen 40 by going from tr6's to an NGk 8 and cleaning up the tune because the new plugs can handle it without knock rah-tard.
Old 04-12-2010, 11:09 AM
02 BLK WS6's Avatar
I run an Autolite 103 for street. I change my plugs to a heat range 8 or 8 1/2 to spray a decent sized shot.
Old 04-12-2010, 11:30 AM
be easy on the OP. he is a good guy and really does know race cars. in fact, he is faster than many in this post and has done it many times.
Quick Reply: Spark plugs and nitrous??
