Drag Racing Tech
Hood for 4bbl TB
Old 05-18-2010, 07:56 AM
buzz12586's Avatar
Default Hood for 4bbl TB
I plan on running a 4150 TB on the 408 I am building and I was wonder what hoods you guys are using? When I drive it on the street I will use a carb hat and piping to a filter but at the track I will just run an open TB.
Which hoods are going to give me enough clearance?
Old 05-18-2010, 08:34 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Check out VFN, as you will need a higher cowl to clear it. What intake and will it have a spacer??
Old 05-18-2010, 08:35 AM
buzz12586's Avatar
Victor Jr and a Wilson Pro Flow plate
Old 05-18-2010, 11:19 AM
1CAMWNDR's Avatar
You will not need much hood if at all. My Victor Jr. and Accufab 4150 with a Spectre carb hat fit under a flat VFN hood. The cowl on the other hand . If you have a shorter carb hat you might get away with the plate also.
Old 05-18-2010, 11:35 AM
buzz12586's Avatar
Haha yea I know I'm going to have to cut the cowl. Do you have any pictures of your setup?
Old 05-18-2010, 03:04 PM
IH8FORD's Avatar
I have a GMPP intake and a NOS cross bar plate (about an inch think) and a carb style breather on mine. The hood is a VFN 3 1/2 inch ss hood Bolt on.
Hope these help.
Old 05-18-2010, 03:17 PM
buzz12586's Avatar
Thanks for the pictures. I really like the look of the Sunoco wide hood. Just have to decide if I want the bolt on or pin on.
Old 05-18-2010, 06:40 PM
1CAMWNDR's Avatar
Here ya go:
https://ls1tech.com/forums/drag-raci...tock-hood.html
Posts #8 and #9.
Old 05-18-2010, 08:05 PM
studderin's Avatar
check these out
edit
opps, your loking for hood room.
Attached Thumbnails Hood for 4bbl TB-008-1.jpg   Hood for 4bbl TB-35iausx.jpg   Hood for 4bbl TB-55j700.jpg   Hood for 4bbl TB-100_1179.jpg
Old 05-18-2010, 08:07 PM
studderin's Avatar
ya a VFN pin on is thin in the back and you gain a bunch of room. I have a sunoco, but even without the cowl its still 2-3 more room then the stock hood thats thick to meet the weather stripping.
I'm not sure what hood this is? hopfully somone else notices it? I remeberit was the same car, he had a elbow, and carb hat setup. But is his a bolt on hood, I can;t think of what style has the screen on the back of the cowl?
Attached Thumbnails Hood for 4bbl TB-9412219710.jpg   Hood for 4bbl TB-9412265839.jpg
Old 05-19-2010, 06:23 AM
buzz12586's Avatar
Thanks for the pics. Looks like I might be able to get away with the stock hood and no nitrous plate. Then when I add the plate I might have to get a hood.
Quick Reply: Hood for 4bbl TB
