Formulas with 28x10.5 tires pics please
Just wondering if you needed to mod your wheel wells for 28x10.5 slicks. I know Camaros and TAs need some trimming but what about a Formula???? I had 27x10.5 QTPs and they fit just fine with room to spare, now im putting on 28x11.5 QTPs and they are about the same size as a MT 28x10.5 ET DRAG, maybe even a tiny bit smaller.
I had 28x11.50R15 ET Streets on my 15x10 6.5" BS wheels and they fit fine. My fenders were already rolled but they cleared.
If you are running them on a 8" wheel I think you will be ok. Their tread width is something like 8.6", which is way smaller than a 28x10.5 ET Drag on a 10" wheel.
EDIT: Nevermind, I didn't know those QTP's ran soo much wider!
The 28x11.5 QTPs are thinner than 28X10.5 ET Drags. I put them side by side both new. They were about 1/4" wider which I thought was strange considering the 11.5 vs 10.5 rating. And yes they are on a 8" rim with 5.5 bs.
I should quit being lazy and just go put them on and find out. They are already mounted and 2ft from the car. lol
Get of ur *** and find out lol, take some pics too. I've been wondering the same thing for the last couple months If mine are gonna rub 28x11.5 et streets but I've also been to lazy to put them on the car. I know you've been waiting too, but finally the nitrous outlet stuff is in shipping.
LS1Tech Co-Founder
Depending on the actual tire you run, and rims you run, you might have to do all or any of the following:
-trim the bump stops
-hammer in the inner fender area that would up high and towards the front... let's call it 2 oclock on the passenger side, and 10 oclock on the driver's side.
-might have to deburr/hammer in front lowest sheetmeal
-hammer in/cut inner fender around the rear lower control arm mount
-might have to do a little bit of cutting of the rear bumper inside lip.
pics
325's/bogarts:
![](https://www.fquick.com/images/vehicles/full/6952145750.jpg)
same;
![](https://www.fquick.com/images/vehicles/full/6952145763.jpg)
same
![](https://www.fquick.com/images/vehicles/full/6952145779.jpg)
28w bogarts:
![](https://www.fquick.com/images/vehicles/full/695239072.jpg)
28w bogarts
pics
325's/bogarts:
same;
same
28w bogarts:
28w bogarts
![](https://www.fquick.com/images/vehicles/full/695239073.jpg)
LS1TECH Sponsor
Take a look at my Formula on the link in my sig.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
LS1TECH Sponsor
Thanks, I took off my 28x12.5 ET Streets last yr and swapped to the radials. Going to give those a try this spring. I'm to the point where I need to start on another engine.
Yours is looking good!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
Thanks! So far its gone mid 11s @119.44 NA with way more in it, since then Ive changed out the cam added alot of suspension, changing to 28s and added a Nitrous Outlet system with all the goodies. Hope to put it in the 9s this yr.
Im just trying to see what will be involved with swapping to the 28s before I mount them on the car. So basic rule is I need about 1" all around for growing clearance on the big end?
