Putting in harness?????
Im putting in a Simpson harness. What did you guys do with the factory seatbelt or if you removed it how did you go about removing the part that goes into the head liner???? I really dont feel like taking all the interior panels out.
Thanks
Mike
Thanks
Mike
I left mine in and just tucked the seatbelts in behind the b pillars. Just incase I need to put them back in bcz the harness's arn't DOT approved and my car is mostly street driven.
I pulled all the stock stuff out, The 5 points "I think? " would be safer with no airbags, and the rollbar then the stock belts? So now you have to wear the harness everytime. The camlock is easy. Olny bad thing I dont think the harness think about for a DD, and 5-7K a summer. The tags wore off after one summer, the stiching wore right thu.. I keep ithe SFI tag in the glovebox for tech
Ya right beofre the hoop hot welded for the final time my buddy pointed out its gona be a bitch to get the belts out of the headliner, so I pulled them right then.
Never had a problem with police or inspection guys about the DOT thing.
