Drag Racing Tech
what tire pressure for et drags?
Old 08-27-2010, 07:06 PM
heymoej's Avatar
Default what tire pressure for et drags?
28x10x15..........just like the title........
@ 12#s now & not running on the full width of the tire........normal or no????
Old 08-27-2010, 08:42 PM
xpndbl3's Avatar
I run between 13 and 13.5 on my thirdgen.
Old 08-27-2010, 09:30 PM
heymoej's Avatar
i am also running tubes in them......if that matters?
Old 08-28-2010, 06:15 AM
Race your car!
JL ws-6's Avatar
What width rim do you have them mounted on? That will effect the contact patch.
I ran mine between 12 and 13.5 depending on the track. Never had any luck lower or higher. 10 inch wide rim.
Old 08-28-2010, 01:34 PM
b.d.d.'s Avatar
Depends on the track conditions. I've taken wrinkle walls down as far as 7 psi. I've ran radials with as much as 17 psi. Just depends, there is no right answer.
Old 08-28-2010, 01:35 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
I run my 28 x 10.5 stiff sidewall on a 15 x 8 rim at 15-15.5 psi on my 3600 lb Nova. I don't run anymore than this b/c it will wear out the centers before the sides. You want to run as much air as possible with a consistent hook, and the more weight you run, the higher pressure you should run (keeps the sidewall from wearing out faster than the tread).
What is the power level/times on the car?
Derek
Old 08-28-2010, 02:19 PM
heymoej's Avatar
it ran 10.80 @ 127 with a 1.50 60' out east.....
Old 08-28-2010, 04:15 PM
Race your car!
JL ws-6's Avatar
Should be fine in the 13 to 14 psi range
