408/TH400/S480 shakedown with vid's
Well,
Took too many 3am nights to count in the last couple of weeks, and insane amount of hours over the past 2 years, but the car made it's shakedown passes yesterday and we are still alive!
It was HOT yesterday, around 91* on my best pass.
1st pass off trailer:
1.41 60'
6.2 1/8
Let out before 1/4 to check the car out
2nd pass:
*line lock wiring gave me problems
*tire shake
1.7 60'
6.7@112
10.4@134
Last pass was dead in the heat:
60': 1.41
1/8: 6.2@111
1/4: 9.83@133
WAY faster than we were expecting!
This was done on:
275/60/15
3640 raceweight
7lbs off the wastegate only
2500rpm 2step on the trans brake
19psi in tires
DA: 2500
I NEVER thought it was going to just hook and book like that on the 275s either. Hahahaha
http://www.youtube.com/watch?v=4B_78Cztjrk
http://www.youtube.com/watch?v=OMfMGxOKt5s
1.41 60'
6.2 1/8
2nd pass:
*tire shake
1.7 60'
6.7@112
10.4@134
60': 1.41
1/8: 6.2@111
1/4: 9.83@133
This was done on:
275/60/15
3640 raceweight
19psi in tires
DA: 2500
Trust me, I wasn't expecting it either!!!
275/60/15 M/T Drag Radial
That was actually 19psi in the tires on that pass
-Drag bar set at neutral plus .5 crank preload1
-Front shocks 2/2
-Rear shocks D6/P7
-TA was 3* of seperation with -2 on the rear end angle(Midwest chassis TA)
-STOCK front suspension
-shocks are Hal QA1 F series 12 way single adjustables
O yea, and the car is just on the wastegate spring. That was 7psi. It was 640 to the wheels on a load bearing dyno-dynamics dyno......
Lest i not forget, the Converter is MONEY for this car!!!! Big props to FTI on that one!
