Trans Temp Sending Unit Location
Where would you guys recommend installing the sending unit?
I have searched and read too many threads and just want some honest opinions now. What makes the most sense to me is the cooler pressure line leaving the trans and heading to the cooler. I have heard the pressure port doesn't actually see significant trans fluid so it really just gives a case temp reading.
I appreciate the replies
Race your car!
My old Th400 I just put it in the side of the case where there was a hole for it. I've heard of people putting it in the pan, the cooler pressure side, etc.
To me, in the case is fine, or in the pan is fine. I don't think I would put it in the pressure side of the cooler line, just because that's one more place that's high pressure that could leak.
In the case or pan it's not exposed to the pressure, making for less chance of a leak, so to me, that makes. more sense.
Overall it's a preferance thing, everyone you talk to will have a different place and a reason for their choice. The temp ga. is just there to maks sure, that you aren't getting it too hot. Doesn't need to be killer accurate, just let you know when the temp's up there so you know to let it cool off for a while.
The pan is where the sending unit belongs...
You need to know fluid temps before it goes back into the pump. This is will tell you the efficiency of the cooler.
Installing it elsewhere is like not having a gauge at all.
heat rises, if you put it in the pressure line, you will be reading the hottest temp of the fluid. If you put it in the pan, you're getting an average temp of fluid not in circulation. If you put it in the pan, you may have to braise around the sender to seal it. I think the senders are brass, pans tend to be aluminum. don't know how well that works out. I would avoid silicone to make a seal as it could get into the valve body.
Gingervitis Addict
FYI hottest the trans fluid will ever be is the cooler line exiting the transmission, as it is right out of the converter.
right, that's why mine is on the pressure line and not the return.
dfddfd
I'd imagine the pan is recieving cooled fluid from the cooler.
