Drop 15lbs off your heat and still keep it...
center console looks just like stock...only thing you have to do is close the front vents or you can see into the dash...
the blend door still works which is the hot/cold ****...
also the heat/ac **** works too as an on/off switch...whenever it is on any of the heat settings it is on...
Excellent got done with everything but the block off plate today since I didn't have a sheet large enough lying around
One question though
On top of the blower motor do I need that piece ? Has the little "door" that rotates up and down.
If I don't need it.. did you close off the opening that goes up into the cowl/windshield wiper area?
Thanks a ton
Very helpful
One question though
Thanks a ton
Very helpful
