Drag Racing Tech
How did you mount your Rear AFCOs??
Old 11-06-2010, 11:42 AM
AChotrod's Avatar
Default How did you mount your Rear AFCOs??
I got some Madman brackets with my shocks your supposed to weld to the shock mounting bracket on the axle then bolt the shock to the madman bracket. I really didnt want to weld it on so I just tuned the shock and mounted it up the normal way with a grade 8 bolt and a spacer. The adjustment **** on the shock does clear the UMI drag bar but its kinda close. Do I need to be worried about side to side movement on the sway bar hitting the ****?
Old 11-06-2010, 10:02 PM
musicman's Avatar
I know I've read a lot about people killing them, I'd use the bracket just to be safe.
Old 11-06-2010, 10:54 PM
Tensec94z's Avatar
Default shock brackets
You need to use the brackets,it keeps the shocks from going into a bind upon launch,madman fixed the design gm couldnt.
Old 11-07-2010, 12:11 AM
Heyfred's Avatar
My home brew bolt on set.
Old 11-07-2010, 06:07 AM
BLK02WS6's Avatar
I made a bolt on bracket similar the one above... either welded or bolted, you need the bracket or you will damage the shocks...
Old 11-07-2010, 06:15 AM
SS4Luck's Avatar
Id be worried a bolted one could potentially rotate a little bit and really eff things up
Old 11-07-2010, 10:43 AM
Heyfred's Avatar
Used splined wheel stud. Pressed into the bracket , then splines extending past the shock mount engage in the housing shock mount when tightening down.
Old 11-07-2010, 01:03 PM
AChotrod's Avatar
Im making some billet alum bolt in brackets. We made them out of a solid block anyone think alum might not be strong enough? Its like triple the thickness of the org weld in bracket. I like the wheel stud Idea also.
Old 11-07-2010, 01:53 PM
99.9percenter's Avatar
I need that with a 1"-2" dropped shock mount location.
Where could I find some?
Old 11-07-2010, 05:32 PM
Fast_94_Z's Avatar
bought a new rear end when i did it.....^^good solutions up there
Old 11-07-2010, 09:46 PM
AChotrod's Avatar
heres the bracket we made.
Old 11-08-2010, 12:31 AM
Heyfred's Avatar
What size radius do you have at the bottom of your cut?
Old 11-08-2010, 03:12 AM
Tensec94z's Avatar
Just curious,why dont you use the ones madman gave you ???
Old 11-08-2010, 08:08 AM
mad_steve's Avatar
x2?????
Old 11-08-2010, 09:00 AM
WhiteLTone's Avatar
I think he was saying b/c he didn't wanna weld them to the rearend. I like the aluminum ones ya fab'd up! Got another set laying around?? Lol
Old 11-08-2010, 10:30 AM
AChotrod's Avatar
Ya I just decided I didnt want to weld them. The only welder I had available was a flux wire welder and I just didnt trust it to penetrate deep enough. Then I just started thinking about a bolt in application.
Heres the bracket b4 the final adjustments and mounting. We had to mill down the bolt head and the inside of the bracket just a bit so the shock body didnt hit anything.
Old 11-08-2010, 11:14 AM
Zmg00camaross's Avatar
Looks like it would work to me, What is the benefits to going coilover than the shock and spring. (height adjustment only) or is there a benefit for takeing it to the strip?
Old 11-08-2010, 11:38 AM
AChotrod's Avatar
Im not using them as coil overs so I can run stock style suspension classes.
Old 11-08-2010, 12:43 PM
musicman's Avatar
lol, you had access to a mill but not a welder? I can't say I would trust aluminum there, but hey if it works, it works right?
Old 11-08-2010, 12:59 PM
AChotrod's Avatar
We had a MIG and TIG at the shop but no way to get the car there, or the welder to the garage. Plus I decided I wanted a bolt in application. The machine shop owner thinks the alum will be strong enough thats why we went so much thicker with it over the supplied steel brackets.
Quick Reply: How did you mount your Rear AFCOs??
