Drag Racing Tech
98 Camaro ......Project 6's pics pics pics
Old 02-13-2011, 08:29 PM
nostixs's Avatar
Default 98 Camaro ......Project 6's pics pics pics
Been meaning to start a build thread for a while and just been so busy i havent.....so hear goes....
98 z Camaro
lq9 block factory crank scat i beams wiseco pistons and rings balanced bottom end patriot predator heads custom cam from thunder racing factory rockers with trunion upgrades
Some may hate me for this but i am going distributor and carb.
Built th350 trans 3800 stall
Factory rear for now ...running low on money im sure nobody knows what that is like lol
Full tubular BMR front end with manual rack...factory springs and struts for now. Subframe connectors Panhard Bar.
Custom fuel system with fuel cell.
Removed all the basic weight savings hvac door bars rear armrest bars all the basic stuff...but my favorite is the amount of wiring i removed 29.5 pounds. Just gutted the factory harness and i only kept wat i needed or wanted.
6 point cage and factory seats for now.
Tell me what you think....
though it was a cool pic
check out my high lift jack. two 4x4's equals higher car
thought this was funny brought her some with the tires tucking
was not happy at all with my welds on the sfc but they penetrated good just wasnt pretty ..im not good at welding on my back.
all of the interior wiring hard to tell but there isnt much there.
upper radiator mounts i made
Old 02-13-2011, 08:31 PM
nostixs's Avatar
a couple more pics ........
Old 02-13-2011, 09:09 PM
bfurches's Avatar
Looking really good so far. I love the way you did the cowl. Thats exactly how I think I am going to do mine. What gauge steel did you use? Keep the photos comming!
Old 02-13-2011, 09:13 PM
nostixs's Avatar
thanks the cowl turned out decent....i believe it was 22ga i got it at lowes our lowes has a decent selection of metal the local metal supplier would only sell me a 4x4 sheet and i didnt need that much.
Old 02-13-2011, 09:16 PM
bfurches's Avatar
Cool. I will take a ride over there tomorrow and check out my stores selection...
How do you like the dizzy cover...I am actually going the same route on my L92
Old 02-13-2011, 09:22 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Looking great. Good luck.
Old 02-13-2011, 09:41 PM
nostixs's Avatar
thanks i like it and think its gonna work very well for the direction im heading..hopefully the car will go to paint this weak and when it gets back i will get my brakes redone and the motor back in
Old 02-13-2011, 10:04 PM
fuel's Avatar
nice job ane nice pics........
Old 02-13-2011, 10:10 PM
highrpmlaunch's Avatar
Great project. Plan on finishing mine when I finish school after this semester.
Old 02-14-2011, 08:00 AM
nostixs's Avatar
idk why i never mentioned it in my original post ...but the motor is a 370ci ...must have slipped my mind
Old 02-14-2011, 10:26 AM
bfurches's Avatar
Do you happen to have the part number for that distributor? Does this setup require any special gear on the dizzy?
Old 02-14-2011, 12:44 PM
nostixs's Avatar
not off the top of my head ..im at work now but i will snap a pic of it this evening and post it ..it is for a small block ford 302 i do know that
Old 02-14-2011, 02:50 PM
bfurches's Avatar
Perfect, that explains enough. I know it calls for a small block ford dizzy but I wasnt sure whether or not it was for a 302 or 351 since they have different deck height.
...last question....for now lol....
I started cutting out my cowl today, and I was comparing the way I am doing it too yours. My question is...when you welded the new flat panel back in on the firewall, did you weld it above or below the stock seam? I dont have a photo handy because I just got to work, but like about an 1" above the HVAC cut-out all across the firewall there is a body seam. I guess I am asking did you cut above this seam or right on it to weld your new piece in?
If you have a photo of just the opening from when you cut, that would be perfect!
Old 02-14-2011, 03:32 PM
Reject's Avatar
nice i cant wait to see more pix!
Old 02-14-2011, 04:49 PM
nostixs's Avatar
here is the part number
the way i did mine was about 1/2 to 1 inch above the bend behind the cowl the only issue i ran into was when welding neer the factory body seam the sealer was heating up and causing my weld to become contaminated....doesnt hurt anything but does make the weld ugly
Old 02-14-2011, 04:50 PM
nostixs's Avatar
ask all the questions u want man i dont mind at all anytime i can help ya out let me know
Old 02-15-2011, 08:13 PM
nostixs's Avatar
a little update got the underside painted tonight and installed bmr chromemoly tq arm ..really nice piece btw. bout it gotta get the car to paint so i can get the motor back in.
Old 02-15-2011, 08:42 PM
96ls10's Avatar
Looks slow. I know there are some pics of the cowl cut out for this nice fella. U gonna post that ****.
Old 02-15-2011, 08:49 PM
nostixs's Avatar
wat pics u talkin bout didnt know u had anymore
Old 03-22-2011, 07:55 PM
nostixs's Avatar
SO TIME FOR A LITTLE UPDATE
its been a while but been busy gettin stuff done
Quick Reply: 98 Camaro ......Project 6's pics pics pics
