Drag Racing Tech
Installing my new tubular k member a arm and coilovers!
Old 02-27-2004, 09:08 PM
04Z06's Avatar
Default Installing my new tubular k member a arm and coilovers!
Here are my pics of my tubular k member a arms coilovers and bear brakes. They look cool and they should perform great. When I get to the track I will let everyone know how they worked.
Attached Thumbnails Installing my new tubular k member a arm and coilovers!-coil-1.jpg   Installing my new tubular k member a arm and coilovers!-coil-2.jpg   Installing my new tubular k member a arm and coilovers!-k-1.jpg   Installing my new tubular k member a arm and coilovers!-k-2.jpg
Old 02-27-2004, 09:37 PM
Kent1's Avatar
It looks great. This should help big time in weight reduction and off toward the front of the car. Cheers......
Old 02-28-2004, 01:04 AM
2001SS#3013's Avatar
What coilover kit is that?
Old 02-28-2004, 01:48 PM
04Z06's Avatar
Its the performance automotive kit. Everything in the picture except the strutts came from PA. It bolted on so easily I could not believe it. PA was great help on the phone as well. Five stars for tech support and quality of the kit. I will let everyone know how well it works on the street and track as soon as I get the engine finished and installed.
Old 02-28-2004, 01:53 PM
04Z06's Avatar
Your right Kent! I think this kit is worth about 76lbs. I am also installing a liftoff fiberglass hood. I hope the weight savings makes a big difference. By the way SS, I was wrong. The brake setup came from Bear. My bad!
Old 02-28-2004, 03:23 PM
Nytmare's Avatar
04Zo6, Where is performance auto? Do they have a website ?
Old 02-28-2004, 05:28 PM
04Z06's Avatar
They do have a website. Do a search. You can even adjust the coilovers by hand because of the roller thrust bearing between the spring and the adjusting ring.
Old 02-28-2004, 06:54 PM
Ru2slo_99's Avatar
Click here.
Can you take some pics of the header clearance when you get the engine installed?
Old 02-28-2004, 07:07 PM
04Z06's Avatar
Sure. I have hooker super comps now. Full lenght. Mufflex 3in y-pipe and 4in after. Spin tech muffler. I had a buttload of clearance problems with the old k member. The new one is lower also. You can tell by the brake lines. I did not bend them yet. Where they are in the pic is where the old k member was.
Old 02-28-2004, 08:31 PM
Ru2slo_99's Avatar
That is the same exhaust setup I have excect I have a flowmaster. What motor and transmission do you have?
Old 02-28-2004, 08:35 PM
aram's Avatar
Do you know how much the k-member weighed? (just kmember, not a-arms)
Old 02-28-2004, 10:02 PM
04Z06's Avatar
I have the 700R4 right now but am going to put a th350 in later. I got a 383 with afr 210 heads and a ZZX cam form tpis. Its toped with a tpis miniram. This is coming off in favor of a super victor and 750hp series carb. Sorry, I'm going over to the dark side!
The K member was very light, but I am not sure. About 30 lbs maybe? sorry.
Old 02-28-2004, 10:58 PM
I only saw the coilover kit for 3rd gen camaros, do they have another kit for 4th gens or is it the same kit?
Old 02-28-2004, 11:01 PM
04Z06's Avatar
let me talk to my buddy and see what is in his kit. He has a 94 TA.
