Drag Racing Tech
TH400 ratchet shifter or non rachet style best?
Old 11-22-2011, 03:47 PM
GIZMO's Avatar
The Turbo Action Cheater works very well. No missed shifts or first to third shifts.
Old 11-22-2011, 04:10 PM
Roger Blackmore's Avatar
Are you talking about the Cheetah ? They looked good, but didn't look like it would go in the console.
Old 11-22-2011, 04:20 PM
GIZMO's Avatar
Yes (I never was much at spelling!). I don't run a console.
Old 11-22-2011, 04:39 PM
Yea, that looks good. That is a true gated shifter isn't it? Move the shifter left or right and pull back to get to the next gear?
Old 11-22-2011, 05:17 PM
GIZMO's Avatar
You don't need to move it right or left to shift. It has a spring to do that. All you do is slap the handle and it goes into the next gear. Each gear has a solid stop so you have no fear of missing a shift.
Old 11-22-2011, 05:24 PM
Gotcha.
Old 11-22-2011, 06:28 PM
midwestjunk's Avatar
Originally Posted by crashinaz
And yes, you can accidentally click 2nd if your hand is on the shifter and your car leaves decently. With the gate shifter, you don't have to pull through the spring that the ratchet has to re-index the shifter, so it requires less effort... That's why my t-brake button isn't on the shifter.
anyone running the t-brake button in the ashtray in an m6 console? i was thinking about making a plate for the ashtray behind the shifter so i can just lift my hand off the button on the launch.
Old 11-22-2011, 06:33 PM
I had a momentary switch for the Lingenfelter launch control , when the car was a 6 speed, but I didn't have to release it to launch. Just dump the clutch. But it was a good location as far as far as your body position.
Old 11-22-2011, 07:17 PM
LS1SpeedAddict's Avatar
I ran the cheetah in my car when I had a th400, its the best one unless you go to a glide then you should get the percision performance shifter, but thats $$$.
Old 01-09-2013, 11:16 AM
Silverback's Avatar
Originally Posted by AChotrod
I have a pro ratchet and love it so far. Plus it looks **** IMO. Havent had any issues being in the wrong gear, just click it all the way forward to get in first then 2 yanks going down the track.
I'm assuming that's a pro ratchet stealth, What did you do with the reverse lockout leaver?
Old 01-09-2013, 11:26 AM
SMOKNSS's Avatar
I run a pro ratchet in my car. No fear of hitting the wrong gear and simply confirm the shifter is "ratcheted" all the way back or all the way forward.
Old 01-10-2013, 11:04 AM
  #32
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Best shifter I have ever seen or used.
http://www.precisionperformance.com/home.htm
Coach
Old 01-10-2013, 01:40 PM
  #33
Camaro396's Avatar
I like Ratchet style shifters much better. Switched to one and won't go back. I like that the stick always returns to the same position. Also no chance of over shifting or pulling to far. Just click back as hard as you can, click again, and done. No dumb levers to mess with or try fiddling with while shifting to the next gear.
Old 01-10-2013, 05:29 PM
  #34
Originally Posted by midwestjunk
my trans is RMVB. anyone use the TCI outlaw? looks like a nice piece.
I use it on a reverse VB 350 and love it. Never miss a gear (unless holding the shifter on the launch lol) also easyer to get it back in neutral at the finish line for plug reading and what not.
Old 01-11-2013, 09:27 AM
  #35
John02SS's Avatar
I use a B&M Quicksilver ratchet and have it under stock console. I got my stock 6 speed short stick mounted on it with my stock shift ****. Looks like a T56 in 1st gear at park. lol
Old 01-12-2013, 01:53 PM
  #36
JustAFooL's Avatar
I use Hurst quarter stick and have no complaints. 2-3 shifting is fine with lever.
Quick Reply: TH400 ratchet shifter or non rachet style best?
