Drag Racing Tech
I am about to notch the cowl for a carb hat, am I in the right spot?
Old 05-25-2010, 05:31 PM
FASTFATBOY's Avatar
Default I am about to notch the cowl for a carb hat, am I in the right spot?
Should I put the engine in and then do it??
Anyone got some GOOD pics?
Old 05-25-2010, 05:47 PM
tektrans's Avatar
Haha, shoulda measure before you pulled the motor.
I think you will have to cut more than that. If it were my car I'd set the motor in before I made the cuts.
Measure twice cut once right?
Old 05-25-2010, 05:54 PM
FASTFATBOY's Avatar
Well I hadnt planned on a throttlebody change when I pulled it, I found a post with a few pics.
I guess I will set it in there, cover it up and do the measuring.
Old 05-26-2010, 07:29 AM
FASTFATBOY's Avatar
Anyone got pics of a notched cowl?
Old 05-26-2010, 07:35 AM
niceguyyy01's Avatar
I've got some pics, photobucket is down at this minute. I'll post up when it come back online.
Old 05-26-2010, 07:39 AM
studderin's Avatar
Attached Thumbnails I am about to notch the cowl for a carb hat, am I in the right spot?-100_1180.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-100_1182.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-100_1183.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-9412265840.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-9412268725.jpg
I am about to notch the cowl for a carb hat, am I in the right spot?-9412268726.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-brad.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-holley-4150_vic_jr.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-holley-4150_vic_jr1.jpg
Old 05-26-2010, 07:43 AM
studderin's Avatar
Attached Thumbnails I am about to notch the cowl for a carb hat, am I in the right spot?-img3916yv5.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-intake-20001.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-intake-20002.jpg   I am about to notch the cowl for a carb hat, am I in the right spot?-intake-20003.jpg
Old 05-26-2010, 07:50 AM
studderin's Avatar
I maxed alot of limits, nothing more works
Attached Thumbnails I am about to notch the cowl for a carb hat, am I in the right spot?-intake-20005.jpg
Old 05-27-2010, 07:00 PM
robsquikz28's Avatar
**** looks good Studderin.
Old 05-27-2010, 08:17 PM
1CAMWNDR's Avatar
Thanks for posting my pics studderin . I didn't see this post untill now.
Old 05-27-2010, 08:48 PM
FASTFATBOY's Avatar
You ever run this setup with then without the hat on?
Old 05-27-2010, 09:21 PM
studderin's Avatar
Ya, I have my super vic, 4150 FAST TB. looking for a used EV carb hat. Ii;m going to run that. And make a airpan for it too, test both. And a 92mm wlison cast elbow to put my 92mm TB on...
I have a spare cowl trim to cut nice too.
Old 05-28-2010, 08:35 AM
1CAMWNDR's Avatar
Mine is the last 4 pics studderin posted, but no, I have not been to the track to test with the hat and without. But mine is afterall a street car.
Old 05-28-2010, 09:32 AM
IH8FORD's Avatar
This probably more than you want to cut.But I'm running a regular breather on mine.
Old 05-29-2010, 10:50 AM
studderin's Avatar
how is the short turn on the Spectre 9841, it looks like a kink? anyone use the EV taller pro hat?
Old 06-01-2010, 06:45 PM
xtreme2001's Avatar
thats about the right spot to cut it out.......i gotta trim mine some more for my setup........carb'd 383 sbc
Old 04-05-2012, 10:19 PM
ttranssam's Avatar
heres how i did my buddys....but on the back side i welded in a nice plate and matched the vent holes...
Old 04-05-2012, 10:20 PM
ttranssam's Avatar
you can kinda see the plate thats smooth and purddy. thought it was going to turn out like **** buut it ended up being very nice
Old 04-06-2012, 05:57 PM
98 grmrpr's Avatar
Mine in its previous life, I have more pics just not sure where. I will add them if I find them, I think that you will need to cut away more than you have marked out for the throttle linkage.
Old 04-06-2012, 06:11 PM
FASTFATBOY's Avatar
I cut mine as I marked it in the picture and it was perfect.
Quick Reply: I am about to notch the cowl for a carb hat, am I in the right spot?
