Guys on ET streets
16" ET Streets with a good 5-8 second burnout with 12psi cold then I leave at 5K+. It's been netting me a pretty consistent 1.72 60', but I'm still getting some spinning so I'm going to take a look at my pinion angle.
16" ET Streets, 15psi, holding burnout about 4 sec, leaving off idle or footbraking doesn't make much difference in my car. Net result - 1.57 best short time, avg 1.59-1.61.
I start out at 15psi cold and lower it if I'm not hooking. My car is an A4. I blip the throttle as I roll through the water. Roll out a couple feet. Bring the RPMs quickley to 5000 and shift to 2nd gear. I hold it for a couple seconds, till I see white smoke boiling out pretty good. Then spin out of the burnout. Best 60ft is 1.48 on 26x10.5x16 ET streets.
