Motorplate source for Funny Car
Make your own, you're going to have to modify one anyways. I made my own so that I could put the engine at the same height as the mid plate. All you need is a timing cover and a water pump gasket and you can make one fairly easily that will work for your application. Try to keep as much as you can around the water pump holes, don't want them to leak on you.
