Drag Racing Tech
Damn that MADMAN
Old 04-11-2004, 01:04 PM
xxx
xxx's Avatar
Default Damn that MADMAN
I guess his torque arm works.....
This is on Drag Radials
http://www.modernmusclecartech.net/H...wheelstand.WMV
Thanks Brian, now you owe me a set of headers.....
Old 04-11-2004, 02:18 PM
Hawkn01's Avatar
Ouch !! Looks like some wheelie bars are in order. How did the headers and oil pan fare ?
Old 04-11-2004, 02:33 PM
xxx
xxx's Avatar
Default ;lkjfsjfdsjk
It was dark last night but from what we could see the oil pan was fine. We're going to put it on the rack tonight and see what the headers and Kmember look like. So far all we can see is, we lost one inner fender, the fans fell off of the radiator, and lost one pair of Fruit of the Looms.
Old 04-11-2004, 03:20 PM
Moderator
BADZ's Avatar
pinion angle means alot in that wheel stand, been there done that. Now mine just goes about 6" max and low 1.3x consistanly. Travel limiters helps 100% and shocks needs to be at 8 on the frt.
Kent1's Avatar
Ouch!! That was scary just watching it. It sure would have scared me. good luck in fixing......
Old 04-11-2004, 03:38 PM
xxx
xxx's Avatar
Default afdsa
Brady has it at his house and after getting off the phone with him, it looks like more broken parts. The manual rack ended up into the oil pan, headers are toast, if he calls again I think I'm not going to answer the phone.... The wheelies are getting expensive.
Old 04-11-2004, 04:55 PM
LS1TECH Sponsor
Magnus's Avatar
I have a couple of questions.. I'd like to learn a little and perhaps avoid a drastic mistake.
It looks like your front end was sitting low from the start. Was it perhaps riding to low?
What front shocks where you running? Think a stiffer compression shock would have helped?
Also, where you on the gas as the car was coming down?
The wheelies sure do look nice but I'm not ready to even attempt one at the risk of crashing countless hours/$$$ I have in my front end.
Old 04-11-2004, 05:08 PM
xxx
xxx's Avatar
Default ggf
Was the front end to low? yes
What shocks and stiffer? QA1, yes
On the gas? partially on the throttle trying not to hit the wall
Old 04-11-2004, 05:18 PM
JoSeY's Avatar
Madman's stuff works...and works VERY WELL....whatcha need to do is call Brian and let him know what the car is doing and he'll give you a starting place w/the TA settings that will probably not give you the 60' you want, but will stop the wheelies and you can start adjusting the TA one setting at a time till you get the 60' u want and not have the wheelies. He did it w/me when we went out to Sealy here in Houston several times...very good guy I can't say enough about him.
Old 04-11-2004, 05:19 PM
xxx
xxx's Avatar
Default sdfhfgjurtuyi
Yeah I can't say enough about the ***** either.
Old 04-11-2004, 06:16 PM
JoSeY's Avatar
LOL...he can come accross as that but after you get to know him....(I've known him personally for probably 4 yrs now)....after you get to know him he's just having a good time.
What makes you call him a *****??
Old 04-11-2004, 06:24 PM
LS1TECH Sponsor
Magnus's Avatar
Thanks for the info.
It's easy to pause the video and say this should have happened or that shouldn't have happened but in the actual event there is no time for any of that.. and great point about the wall.. I too would be worried about it.
Good luck with the repairs.. At least you got a video of it.
Old 04-11-2004, 07:41 PM
SMOKIN01TA's Avatar
Old 04-11-2004, 08:17 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
WOW & Ouch!!! Good luck on the repaires. Cool that your ok.
Yea, "Oh Madman" can make them hook. Thats why his names on my car.
What Mods do you have?
Coach
Old 04-11-2004, 09:44 PM
xxx
xxx's Avatar
Default kljkj
Coach
Hi Coach long time no talk...
540" EFI
Powerglide
9" w/ 373's
315/60 DR's
This pass we were spraying a 275 dry shot out of the hole....
Josey I call him a ***** because he is a friend of mine..... (and he is *****)
Old 04-11-2004, 11:34 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Impressive wheelstand, but OUCH! Don't let Brian buy you any new underwear though, it might have a bunch of holes in it
Old 04-12-2004, 10:04 AM
Motorboater
SilverGhost's Avatar
lol, lost one pair of fruit of looms..damn i'm easily amused this morning
not often you see that done on drag radials.
Old 04-12-2004, 10:07 AM
gator's 99TA's Avatar
amazing traction out of a set of BFG tires!
Old 04-12-2004, 12:04 PM
Colonel's Avatar
Having the frontend low is a good thing, IMO.
Old 04-12-2004, 12:32 PM
Billy the Great's Avatar
540" EFI
Powerglide
9" w/ 373's
315/60 DR's
wow sounds like what i wanna run in a few years when my z retires from daily driver dities. Got any pics of the bbc in the car. What are you using for headers?
