Drag Racing Tech
Launch off idle or brake stall?
Old 01-22-2013, 12:24 AM
Bullitt117's Avatar
Default Launch off idle or brake stall?
I've been wondering about this for a while. My '00 Trans Amwill have dot slicks and a small stall. Full bolt ons. What will I see better results from, launching off idle or brake stalling up to around 2400?
Old 01-22-2013, 12:33 AM
lemons12's Avatar
Most see the best results from just taking the slack out... IE 1000 RPMs or so.
You have to try every different way to see what your individual setup likes the most however.
Old 01-22-2013, 10:08 AM
Bullitt117's Avatar
Sweet, I'll just have to try a few different things.
Old 01-22-2013, 10:16 AM
Camaro396's Avatar
Every car likes something different. My car would always go about .10 faster just flashing the converter off the line, than if I tried footbraking it. Others go faster footbraking rather than flashing. All depends on your power, weight, gear ratio, converter, etc.
Old 01-22-2013, 11:16 AM
cj92345's Avatar
yep, 12-1300 rpm
Old 01-22-2013, 06:11 PM
1BAD98LS1's Avatar
Footbraking is a little easier on parts... IE 10 bolts lol
Old 01-22-2013, 08:23 PM
1320Chicken's Avatar
1500 gives me the most consistent and best 60fts. Best bet is to spend a test and tune trying different techniques a couple times each.
Flashing it hurt my reaction time but it doesn't make a difference if you're running for fun or et.
Old 01-30-2013, 09:41 PM
Lazzarus's Avatar
For me, just bringing it up to about 1k RPMs and flashing it works best. Yank SS3600 converter, cam only car.
Old 01-31-2013, 03:29 AM
Mighty Whitey's Avatar
It's all in what your suspension will let you put to the ground.
My edge "3400" which acts more like a 4000, seen better 60' times the higher I stalled it, up until about 16-1700. after that (around 2k) it seemed to get in to the power a little to quick and wanted to spin 5ft out. But, I could footbrake he car to 3k, no problem and still flash it a little I the launch, so it's loose compared to some other mid-3k converters.
Generally, if your car 60's better off idle than footbraking it, you're converter is too tight.
Old 02-07-2013, 09:45 AM
chrs1313's Avatar
Stall it up as high as it will go...just makes sense if the proper converter is used...
The whole point of the converter is to get in the upper rpms faster where it makes more power...so get it up there by brake stalling it higher
1.28 60ft with n/a sbe
Quick Reply: Launch off idle or brake stall?
