Drag Racing Tech
Bogart wheel pics
Old 05-21-2004, 01:49 PM
The Juggernaut's Avatar
Default Bogart wheel pics
I figured this would get more attention in the drag racing section.
Does anyone have pics(mounted) of Bolted R/T's with a 2.5 backspacing on the front?1 3/4 is standard, but deep 2.5 is an option.
Post 'em if you got em!
PS they don't have to be R/T's, I'm really only interested in how a 2.5 backspacing
looks mounted.
Thanks!
Sean
Old 05-22-2004, 12:02 AM
So Slow's Avatar
I guess I have the standard bolted RT's but I cut the 1" spacer Bogart welds onto the wheel..I had to grind the front calipers to get the wheels to clear but now the wheels look so much better on the front of the car..
Don't get me wrong the wheels looked fine but I didn't like the spread out look it gave the front of the car..I'll get pictures in the morning and post them up for you..
Old 05-22-2004, 06:27 AM
Gimp98TNT's Avatar
Man i wish I knew they had that option when i got mine. I already had to grind the **** out of my front calipers to fit welds with no spacer.
Old 05-22-2004, 09:27 AM
I think you can only run the deep backspacing if you have drag brakes.
Any pics would be appreciated!
Old 05-22-2004, 12:04 PM
WILWAXU's Avatar
PM Tim (Hawkn01) He runs the Bogart "aluma lights" set up for the drag brakes, not sure if he has picture though...
From what I've been told, they're basically the same rim without the spacer welded on the back.
Old 05-22-2004, 12:07 PM
WILWAXU's Avatar
Here's pictures of the Aluma Lights on Joe Overton's car:
Old 05-22-2004, 12:27 PM
So Slow's Avatar
I think you are correct about the drag brake setup..I was going to install a Aerospace front brake kit then cut the spacers off to get the wheels to fit inside a little better..But I saved the money for now and just took a grinder to the front calipers...
Maybe later I'll still install the brake kit for the weight savings..Here is some pictures to give you a idea how the wheels fit now..
Old 05-23-2004, 08:07 AM
Are those 15x4 or 3.5?
What was the back spacing before you started grind and how thick was the spacer?
Old 05-23-2004, 11:01 PM
So Slow's Avatar
The rims are the 15 x 3.5" with the 1 3/4 backspacing..The spacers was 1" wide..
Old 05-24-2004, 02:46 AM
BIGBOS's Avatar
So slow, what model of bogarts are those?
Old 05-24-2004, 06:09 AM
So Slow's Avatar
They are the Bolted RT's..
Quick Reply: Bogart wheel pics
