Drag Racing Tech
B4 i delete the front swaybar
Old 10-01-2014, 01:48 PM
sleepy00's Avatar
Default B4 i delete the front swaybar
What's your best 60ft. with it connected? Not worried about body roll, mostly long straights in the south. Also will the front raise sit up higher when on level ground?
Old 10-01-2014, 02:00 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I cut 1.5X 60ft times in my old daily driven T/A with no front sway bar. I daily drove the car for three years without any kind of issue. Taking the front sway bar off will not effect the ride height at all.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-01-2014, 02:28 PM
willizm's Avatar
with it connected I was cutting 1.6's. Removed and viking shocks i'm cutting 1.3's. My sway bar bolts broke off and never reinstalled it. Handles fine but you will notice that it's not there initially. you get use to it.
Old 10-03-2014, 05:38 PM
VandykeT/A's Avatar
I was cutting low 1.7s on a 26-10.5 Mickey. Took off the sway bar and went to a 27-11.5 Hoosier and cut 1.5x. Stock bottom stick car. You'll notice it when hitting a curve and goosing it from a 1st gear roll but it's nothing major at all. Like he said you'll get used to it. And ride height will stay the same.
Old 10-03-2014, 05:49 PM
senicalj4579's Avatar
Best 60 with sb 1.7
Best 60 without 1.5
That was with the old 3600 stall. Not sure what it will do now with the 4k stall and built trans.
Mt drs.
If your not worried about handling/body roll just take it off.
I keep mine on the street. I am one of the few who can feel something missing that should be on a street car. Just my taste though.
Old 10-08-2014, 10:43 PM
los p's Avatar
1.28 with it still being on....i took it off once and 60 times went up so i put it back on
Old 10-08-2014, 10:52 PM
NW Iowa WS6's Avatar
I went from a best of 1.90 to 1.76 back in my clutch slip radial days, now I've been running no front sway for 4 years and haven't looked back. Ride height does not change but when you punch it in 1st the front raises up alot more and in between shifts as well, makes the car feel faster too. It also rides a LOT smoother, front end floats over bumps like a caddy now haha. Downside is autox and road racing type things will be greatly diminished with a lot more body roll taking hard corners.
Old 10-10-2014, 03:54 PM
01ssreda4's Avatar
So far I've enjoyed mine off. It lifts in the front more and quicker. Handling you won't even notice if you drive around normal. Actually yeah it does ride smoother now without it. I did a drag bar in the back and skinnies at roughly the same time.
Old 10-13-2014, 01:06 AM
Kingc8r's Avatar
LS1Tech 10 Year
Yup I DD mine for over a year with no sway bar. Then again I also drove regular/cautiously and didn't try any crazy maneuvers. I preferred it off as well.
Quick Reply: B4 i delete the front swaybar
