Trying to make the most of the last test n tune
Im still on strano springs and kybs (getting vikings over winter). Front shocks are set to 1, rears are set to 3 for now.
Tires are 295/55/15 et street radials, will drop down to 16 psi.
Front sway bar is out. I wasn't getting much for weight transfer before, hopefully this helps.
Im really just hoping to get a 1.7 60ft. I touched a 1.8 on the 17" radials before, but missed a gear on that run. Usual track has crap prep, going to Summit Raceway Park for the first time finally.
Last trip out, only got 2 runs in, first spun pretty bad. Second run I did a better burn out, tried to slip it out from 3500ish rpm, bogged down to under 2000. Finally hooked but it almost died. Im going to try around 4500-5000 and slip the clutch a bit this go around.
I trapped 96.6 in the 1/8 and 121 in the 1/4 before with the 26" tires, how badly are the 28s going to affect me? Any more tips, or changes I could make before I go?
I would try to go a little lower in tire pressure. No front sway bar helps a ton. I don't see why you shouldn't be in the low 1.7's to high 1.6's.
-Mark
-Mark
