Drag Racing Tech
Where would you shift it
Old 11-24-2014, 11:41 AM
99french's Avatar
Default Where would you shift it
I usually try to shift at 6300-6500. Do you all think I should shift sooner? Car now has 28-11.5-15 qtp on it. Trying to secure my 11s time slips next 1/4 trip. Had it 11.75 once and breakages and driver mod has only netted another best of 12.001 @ 117 I think. I'll have to dig back through the slips. Just need some advice on where to shift her with the stock t56
Old 11-24-2014, 02:19 PM
93camaro_zzz's Avatar
If it were my car, I would raise the redline to 7000, and shift it at about 6800. You seem to have a good valvetrain setup.
Old 11-24-2014, 05:08 PM
Doug G's Avatar
Try a few hundred lower and higher....see what it wants
Old 11-26-2014, 08:36 AM
Bitemark46's Avatar
I think on the dyno the person should have taken it a little higher to see where the power really starts to fall off.
But if it's carrying at 6500 still like 93camaro said I would try 7k. If your tranny ratio drop is huge between 1st and 2nd then you may need to go higher.
But maybe try 1-2 -7000, 2-3 6800, 3-4, 6600.
You're in Oldsmar. 25 minutes from me. Howdy neighbor!
-Mark
Old 11-26-2014, 10:14 AM
guppymech's Avatar
Check out this post by Mike V. on shift extension. Good info there.
https://ls1tech.com/forums/drag-raci...l#post16001189
Old 11-26-2014, 11:47 AM
WE TODD DID's Avatar
Wherever you shift at, your shift drop needs to be at your peak rpm.
Old 11-27-2014, 11:56 AM
99french's Avatar
Thumbs down Over 7k dyno graph
Here is the graph from a different dyno at a car show summer of 2013. I took to 7100-7200 rpm. Sounded damn cool although I do worry about the stock bottom end holding together
Old 11-27-2014, 01:44 PM
scotty2000ss's Avatar
I'd shift at 7k seeing your dyno sheet. If you run a shift, light set it to 6800 and call it a day
Old 11-27-2014, 09:59 PM
Bitemark46's Avatar
Yeah I think I agree. 6900-7k on the 1-2. Then maybe 6800 on the 2-3 and maybe 6600 on the 3-4.
-Mark
Old 12-01-2014, 06:02 AM
SweeTbone's Avatar
I'm with the others and set the shift light at 6800. That's where mine is at. My 2 step is set at 6300 for launching. Also with those 4:11 gears in the rear end you might want to go with a 26" tire over the 28". I've had pretty decent luck with the 26" ET Drags so far.
Old 12-07-2014, 10:26 AM
99french's Avatar
I tried 26" et streets with no luck. Plus I'll be spraying it very soon. Had my best results on a 28" qtp so I went back to them and haven't been to the track yet this year. So next time I'll shift it higher and see what happens.
And howdy neighbor.
Quick Reply: Where would you shift it
