EFI super victor, spacer or no spacer under thottle body....
So I see a lot of the carb guys with super victors on here run 1" spacers under the carb. I have a EFI version of the super victor with accufab 4150 throttle body. Will I benefit from a spacer? what kind and size should I use? I will also have a nitrous plate under this as well. Do you just stack them with gaskets in between?
Setup is a 408 with ported TFS 245's with ported super vic 4150 and Brian tooley custom cam. This is a nitrous motor which will be sprayed 200-400 shot range.
I have a 1" open spacer and nitrous plate between the throttle body and intake. I was told with a single plane intake the more space you can get between the throttle body and intake the better.
