help with hooking dr's on the bottle
Car hooks great na 1.48 60ft. Soon I spray it. It blows tires off. Im spraying 100 with window switch set a 4500. Far as the susp mods goes I have
Qa1s up front.
Ce 50/50 back.
Umi short tq arm -2.5 pinion angle
Lca set middle hole
Spohn antiroll bar no preload
4l60e 3.42 gears mt 275/60/15
Ride height 26 front 28 rear.
Tired 15, 16, 17 tire pressure, shocks 1, 2,3 from full loose. Lca in bottle hole also. All results were 1.5 60fts.
Thanks for any help
Qa1s up front.
Ce 50/50 back.
Lca set middle hole
Thanks for any help
stiffer rear shocks, 2nd on MT pro at 20 psi.
pinion angle is to much. there isn't that much defection in the torque arm that you need -2.5 degrees. I run about -.5 degrees. although I doubt that has anything to do with traction.
It almost looks like the car is starting to settle down and that's when the juice hits upsetting the suspension ?
Do you have lower control arm relocation brackets? Your car sits low and if you can't adjust the control arms to compensate for your ride height that also be some of your problem.
