Drag Racing Tech
Tall Deck block into 98-02 F-Body
Old 10-18-2015, 07:04 PM
GrimReaper's Avatar
Default Tall Deck block into 98-02 F-Body
Just looking to see what types of issues one may have putting a tall deck into this body style. I have a full drag car, cowl is cut back to the windshield...but does that need cut as well?
What intake does everyone run on there tall deck? Or are spacers used?
I'm looking into a tall deck short block, i have a mid plate to clear the Lemons tall deck headers. But I also have the Mast LS3 4500 intake. I really do not want to get lexan and cut out the center section. I also have a pretty big cowl hood as well.
Just looking to see what people have done, any pictures would be great as well.
Old 12-30-2015, 09:30 PM
bboyxclub's Avatar
Bringing back this thread instead of making another one about the same topic. Im currently in the search function trying to find clues ...
Old 12-30-2015, 10:02 PM
Race your car!
JL ws-6's Avatar
I dunno how tall the motor will be overall but I have a tall deck bbc in my car, I have the cowl deleted with a setup that looks similar to the one that Midwest sells. You will need to make room and will need to notch where the glass is at some level, no way around that.
Also, make sure you have at least 4 inches from the top of the TB to the hood, any less than that and you would be well served to just put a couple spacers under the TB and put a lexan forward facing scoop on, without it the airflow into the engine is going to suffer enough to slow the car/kill upper rpm power.
Old 12-31-2015, 12:40 AM
bboyxclub's Avatar
Thanks any more info from anyone is appreciated . I would think the ls tall deck is a bit more compact. Picture you can add ? Thanks..
Old 12-31-2015, 03:19 AM
8 Second Truck Club
Blown06's Avatar
I really can't add any info on fitment in an f body, but I can add that I would do it. You have a race car so there really should be no problems "making **** fit". Now if this was some daily driver type **** that wanted to keep all the creature comforts then that would be a different story. In a drag race application, really the only con I can see that may possibly weigh a little more. That little problem should go away with the additional power created by the additional cubes.
Old 12-31-2015, 04:07 AM
ATwelveSec02Z28's Avatar
Here's what I had to do for a standard deck and Mozez heads
Old 12-31-2015, 07:25 AM
Race your car!
JL ws-6's Avatar
Here's one I had handy on my phone:
Old 01-03-2016, 12:10 PM
Firehawk441's Avatar
Tall Deck RHS Block
Old 01-07-2016, 01:04 AM
bboyxclub's Avatar
I want to stay with OEM glass . ^Thanks for the pictures that gives me a lot of ideas! It seems like a lower profile intake can fit in there?
Old 01-07-2016, 07:25 AM
Race your car!
JL ws-6's Avatar
Oem intake won't work without a spacer made since the heads are further apart.
If you're not willing to cut the car, don't put a tall deck motor in it., you will only be making a power compromise that will negate 1/2 the gains of going to the tall deck in the first place.
Old 01-07-2016, 08:24 AM
MidwestChassis2's Avatar
Here is the pictures of a customer that installed a Midwest Chassis Cowl delete kit.
Like Jl ws-6 mentioned I don't think it is possible to do it and keep the stock glass.
Old 01-07-2016, 11:45 AM
bboyxclub's Avatar
I guess you are right... 4th gens and their cowls.. I dont mind cutting the car, I just would like to stay OEM glass.. apparently OP also has the same idea.
Eric thanks for the picts and thanks everyone else.
Old 04-21-2016, 10:47 AM
tittan1500's Avatar
You can stay with stock glass.....
I cut an access panel under the dash, and a patch plate screwed down. If I need to pull the intake I can take off the dash pad and pull the dist out the dash.
Old 04-22-2016, 12:38 AM
Race your car!
JL ws-6's Avatar
I like those valve covers, where did you get those?
What heads do you have on your 632?
Old 04-22-2016, 12:44 PM
tittan1500's Avatar
They are the 18 deg Pontiac pro stock heads aka what the big chief was designed off of.
The covers can be found on ebay once and a while or Racing junk but they are pretty rare and people want big money for them.
Old 04-22-2016, 04:22 PM
Race your car!
JL ws-6's Avatar
Ok makes sense. The heads looked like spread port but the intake side didn't, kind of threw me for a loop. Little bit older but as you know that doesn't mean a damn thing they make big power.
I have a set of Edelbrock 24 degree victor's on my tall deck 540, they look tiny compared to those.
The headers on your car how much of a **** show are those?
Attached Thumbnails Tall Deck block into 98-02 F-Body-img_1799-1-.jpg   Tall Deck block into 98-02 F-Body-img_1801-1-.jpg
Old 04-24-2016, 09:50 PM
tittan1500's Avatar
Nice setup man, i am going to be focusing on lightning up the front area like you did.
The headers are custom built 2 1/4 primary's from Sharadon Performance in Hugo MN.
They fit nice but ground clearance is a issue with the 4" case mufflers.
Do you have any pictures of the panels next to the hood / wiper area? I was looking into patching that area as well
Old 04-25-2016, 02:07 AM
8 Second Truck Club
Blown06's Avatar
Hey bud, could you pm me or post up some pics of your 2.25" headers? I'm about to build a set for the truck and can use all the pics and help I can get.
Old 04-25-2016, 12:58 PM
tittan1500's Avatar
Old 04-25-2016, 05:15 PM
Race your car!
JL ws-6's Avatar
I built these myself, first set I ever did from scratch. 2 3/8 stepped to 2 1/2 primary, they run into a flowmaster outlaw 2 collector muffler, and out the front.
what you have there looks nice but there's no way I could have put the collector mufflers I have under my car it would have been beating all over the ground just sitting there.
Quick Reply: Tall Deck block into 98-02 F-Body
