Exhaust extension
Exhaust extension
Wasn't sure what to put in the title. I'm getting my car re-tuned in a few days and the tuner wants me to add an exhaust pipe extension to my car. My exhaust it just a 6" bullet muffler attached by a band clamp to the end of my headers.
He wants to add o2 sensors to the headers and wants me to extend the exhaust out so no dirty air comes back while tuning.
Any suggestion what I could use temporary just to get by for the tuner?? I had an exhaust shop cut me a 3" pipe 12" long but it may be to heavy to attach it with a band clamp. Any suggestions would be appreciated. I'm going to check homedepot for a lightweight 3" pipe.
Thanks I'm gonna give this a try. That's what I use now to hold my bullet muffler. The pipe I had cut is on the heavy side and not sure if there is enough lip on the muffler. I'll give it a shot tomorrow night.
Thanks.
Thanks.
8 Second Truck Club
Just tell him to put it in the collector. With mufflers on it, that should be enough pipe alone to keep the **** out. It's only an issue at idle/cruise anyway, and you shouldn't be blowing up motors at idle/cruise. At WOT there isn't any air coming back into the system.
This post is sorta confusing. At idle and light throttle your computer is still trimming your fuel, positive or negative. Then for wot it locks in a trim based on those. So if the idle and lower throttle region are being incorrectly read by stock o2s while being driven, not only will driveability and gas mileage suffer but it will still effect wot as well. The point is it should be done correctly all the time, there is no reason to risk too short of a pipe.
Not sure what "lift" is. It has been tuned previously for no o2's. Not sure if that's what you mean.
If you had it tuned before with no O2 sensors then the tune is a speed density tune that uses the MAP & IAT sensors for calculations. The tuner would most likely use a wide band to tune. Do you know if you are getting a tune for wide open throttle or part throttle or both? Is this the same tuner and if not, does he know that it was tuned before without o2 sensors?
He said no problem he still wants to tune it using o2's just for additional information.
No problem. Just recently put on strange double adjustable shocks on the front and replaced the rears with competition engineering shocks. Rear tires are 28x10 and the fronts i'm not sure about. I think they call it a Volkswagen tire.
The shocks helped some but the 4.88 gear and 4900 stall helped alot. The 1.49 60' pass was from the other day. It consistently runs 1.51 - 1.52 60'.
Also just installed a mwc torque arm bar.
You might get some better responses on this in the PCM tuning section. However, having a lot of experience with tuning, I have an opinion on it. So, if he is using a wideband to tune your car, then you shouldn't have to worry about your WOT regions at all, because as previously said, there will not be any missreadings with that much exhaust going out. You said that the fuel trims were turned off in the tune previously? Does he want to keep it that way, or no? If he wants to keep it that way, then you don't need O2 sensors in the first place. If he wants to use narrowbands in your exhaust, then in my opinion, I would feel comfortable placing them in your collectors. I have tuned cars with much more sketchy setups, including my own. My exhaust is a fender exit turbo downpipe. So it has no muffler. My wideband is roughly 18 inches from the exit of the pipe.
I'll let yall know what I find out in person.
Perfect time to add a tubular K member
