Drag Racing Tech
Heads
Old 09-27-2016, 08:16 AM
ls3fbody's Avatar
Default Heads
I just got a lc9 eng the aluminum 5.3 motor and im Planning on goin turbo with the eng what is the best heads to run for my setup or should I use the stock ones and just port them out!
Old 09-27-2016, 10:15 AM
93camaro_zzz's Avatar
I'm not an expert on what heads come on that engine, but you can pick up a pair of 317 heads for probably $100. Throw some springs on them, and you will be good. Plenty of people making close to 4 digit power on the untouched heads.
Old 09-27-2016, 10:25 AM
ls3fbody's Avatar
Where would I Find those heads at or what did they come on?
Old 09-27-2016, 01:33 PM
Many aftermarket companies will sell the LSA head castings complete. Otherwise, just go look on 5th gen ZL1 forums, and Cadillac CTS-V LSA forums. You might find a pair.
Old 09-27-2016, 01:44 PM
ls3fbody's Avatar
ok so they are LSA heads
Old 09-27-2016, 08:36 PM
Yeah, the ZL1 camaros and the later model CTS-v had the supercharged LSA engine in them.
Old 09-27-2016, 09:46 PM
tug686spd's Avatar
Had to read this twice. Op has a 5.3 liter and is looking for Ls3/Lsa/L92 type head? To the best of my knowledge that will not work unless its an aftermarket small bore head. If boosting the motor as said already people have made plenty of power on the stock heads.
Old 09-28-2016, 09:26 AM
ls3fbody's Avatar
Will the stock heads with work done support 800+hp
Old 09-28-2016, 10:36 AM
tug686spd's Avatar
Yes, your best option right now is to research as much as possible. In the Forced Induction section of this forum youll find plenty of 5.3l builds. A good start might be to google "sloppy mechanic", hes a member of this and many other forums. Very knowledgeable and plenty of builds by him to read through.
Quick Reply: Heads
