Drag Racing Tech
How to launch a pd blower car
Old 12-03-2016, 09:59 AM
jimmyg's Avatar
Default How to launch a pd blower car
So I took my car to the track. It's an 83 cutlass
Ly6/whipple 2.9/ 4l85/ strange s60. 3.73.
60 ft is horrible ( 2.4 ) can't get any traction out of the hole. Car has ride tech coil overs , nitto 555r. 275/40/17. What's my best bet for a better 60 ft? . I can drive but I haven't spent a lot of time at the track. Just trying to get a little better et. Last run was 11.5@127. ( I let off for a sec , afraid of going under 11.49)
Old 12-04-2016, 03:45 AM
8 Second Truck Club
Blown06's Avatar
Shouldn't necessary have anything to do with your "driving ability". Your car simply doesn't work off the starting line. That is a chassis issue.......unless you want us to just tell you not to mash the gas peddle to the floor when the light turns green????
...and if that is the case, why are you at a drag strip? lol
Old 12-04-2016, 05:13 AM
sbcgenII's Avatar
Start with some real tires.
Old 12-05-2016, 09:03 AM
jimmyg's Avatar
I was thinking some 15 in drag slicks . My other question was, can I use something like a 2 step to limit power on launch? My buddy's nova is around 400-450 rwhp and he is running 245/40/17 nittos. He is running 11.7@118. I'm thinking if I can limit power somehow until I at least get rolling some , I should do a lot better. My car seemed to hop off the line until I let off ,then it hooked hard. My rear is fully adjustable , so I'm also wondering if there is something I can change so it will hook better.
Old 12-05-2016, 10:15 AM
1KillerSS's Avatar
This.....Get some real tires, even go 15 inch. I would start there, then worry about the rest. Without doing this first, your going to be chasing your tail.
Old 12-05-2016, 10:44 AM
jimmyg's Avatar
Ok so what's the stickiest tires that will fit? I would like to go 28 in if I can , since it was bouncing off the limiter going thru the traps
Old 12-05-2016, 01:18 PM
T6Rocket's Avatar
Coilovers that are good for handling are bad for the dragstrip.
A 2-step is for consistency, not to limit power. Once you're moving, you are under full power.
You don't have to go to a full slick. The M/T DR's - even in the 275/40-17 work quite well. http://www.mickeythompsontires.com/s...tem=ETStreetSS
Al
Old 12-05-2016, 09:20 PM
jimmyg's Avatar
Al
You think the et streets are that much better than the nitto555r?
Old 12-05-2016, 09:46 PM
1KillerSS's Avatar
They are in two different worlds.
Old 12-06-2016, 12:43 AM
SteenH's Avatar
Not even a comparison.
Old 12-06-2016, 12:20 PM
jimmyg's Avatar
So which ones? Et street ss? I have 275/40/17 nittos now . What can I get that's a little taller? How to launch a pd blower car-photo784.jpg
Old 12-06-2016, 12:21 PM
jimmyg's Avatar
The rears look a little small for the wheel well
Old 12-06-2016, 12:57 PM
93camaro_zzz's Avatar
Get real tires.
Will the car spin if you just mash the throttle off idle? I bet it would. So in that case a 2 step will do nothing for you.
Old 12-07-2016, 01:18 PM
a05c's Avatar
I wouldn't put 555R's in anything but a dumpster.
Old 12-07-2016, 02:54 PM
T6Rocket's Avatar
The ET Street R in 304/45-17 is taller at 28". Should still fit with minimal work.
Judging by the tread design, any wet driving at all is a no-go.
Al
Old 12-07-2016, 07:42 PM
jimmyg's Avatar
Al
Thank you! I didn't know they came that size. I still have 1/2 or so frame clearance so they should go. Not too worried about the rain, this is my week end toy.
Old 12-07-2016, 08:03 PM
onebadbowtie86's Avatar
I got 5 or 6 passes on the 275/40/17 et street ss's before I snapped an axle shaft in my 8.5". they were sticking better then I thought they would, especially since my cars a stick.
Old 12-08-2016, 06:58 AM
jimmyg's Avatar
That's bad ***. I put a strange s60 in mine . Strange usually has free shipping this time of year if your interested.
Old 12-11-2016, 06:12 AM
Race your car!
JL ws-6's Avatar
The 28 inch tall m/t tire that fits the 17 inch wheel would be my first suggestion, if that doesn't do it a 15 inch rim with a bias ply tire would be next, simply so you don't have to redo all the suspension you already bought so it rides/drives nice.
15 inch wheel and a 28 inch bias slick will likely solve all issues, if the m/t radial doesn't.
Old 12-12-2016, 08:52 AM
LS1Tech Premium Sponsor
MidwestChassis's Avatar
What are your spring rates? The ridetech shocks probably are not the best for drag racing being that they are a shock more geared towards handling and comfort not saying they will not work just saying they not the most optimal shock choice.
Quick Reply: How to launch a pd blower car
