First time using the TNT F-1 wet kit
I started out getting the car dyno'd before I went to the track, Here's the numbers: (104* temp)
NA unlocked: 360/359-AF 12.8
NA locked: 371/362-AF 13.0
100 shot N2O: 464.5/531-AF 10.7 (fat)
I also blew out the crank seal on the N2O run, luckily the shop carried the part.
At the track, My best N/A run that evening was a 12.23@111.3/60'1.75, (just did one N/A run) pretty hot out side. I decided to wait till 11:30 that evening to go for the N2O run after it cooled a bit. Man, it was like someone kicked me in the rear, what a rush. Anyway, my one and only N2O run (track closed at 12 mid)resulted in:
60' 1.73
1/8 7.24
1/8MPH 97.83
E.T. 11.22
MPH 124.5
I was pretty stoked considering I didn't hit the ARM switch till the 60' mark, what do you guys think?
Dan
<small>[ July 08, 2002, 05:38 PM: Message edited by: DanZ28 ]</small>
60' 1.73
1/8 7.24
1/8MPH 97.83
E.T. 11.22
MPH 124.5
Dan
Re: First time using the TNT F-1 wet kit
Good numbers. If you come out on the bottle and get the 60' in the low 1.5s you will see some 10.80 or maybe even a 10.70.Back in the late 80s i had a Mustang that would run 11.40 all day long not spraying until the top of 1st gear and then i started spraying it right out of the hole and it would go 11.00s.you will be supprized at how much you will pick up.Good luck.
Thanks jleews6!
I agree with you. I was a little affraid (being my first time) of spraying out of the hole, thought I might brake something like the rear end, next time will be different. I need to bring that AF up a bit, maybe around 11.5-11.8 or so. Later, I will give the 150 pills a try as well..
Dan
Dan
You will get addicted!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Dan
Dan
Your MPH is similar to mine. I ran a 10.86@124.5 with a 1.60 60'. I did not spray out of the hole either. My posi was gone, my 60's are usually 1.52. My dyno HP was 480. So I figure I should be good for a 10.6 sooner or later. You should be able to get similar results, if you can hook & better if you spray out of the hole. Good luck.
Black Sunshine/ 00SS, thats an awesome time!
My 60' is normally a 1.74 with the 26" ET streets and stock 3.23 gearing. If I could cut a 1.5, I would be very happy. I'm hoping for a 10.8x @ 126 or better out of this 100 shot, hope it's possible. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Moderator
Dan Like I mentioned to you earlier today.. You were flying.. Looking over the timeslip on that run with me, you went through the traps before I hit the 1000 foot mark. You were over a football field ahead of me!! Now you know why I go through so much N20.. I really wish I would have had a full bottle <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> .. Can't wait to see that thing squeezing out of the hole, with the 150 shot and AF where it should be!!
Thanks buddy! most fun I ever had at the track <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> , will have to get back soon.
Dan
Dan
