Drag Racing Tech
need help on drag tires?
Old 11-08-2002, 10:00 PM
LARRY01Z28's Avatar
Default need help on drag tires?
ok, once i get the 12 bolt, with 4:10 gears. what size tires should i use or get? i have a bolt on m-6 camaro. its a pretty light car. lt' headers and alot of bolt ons. 3:73 gears in a 10 bolt. best et so far is 11.67 @ 118.20 on et streets, and on nittos it was 11.77 @ 118.90. thanks for the help.
<small>[ November 08, 2002, 10:55 PM: Message edited by: LARRY01Z28 ]</small>
Old 11-09-2002, 01:38 AM
LARRY01Z28's Avatar
Default Re: need help on drag tires?
ttt
Old 11-09-2002, 09:31 AM
GeorgeC's Avatar
A 26" tire would take you through the traps (using 120mph) at between 6300-6400, which sounds about right for a bolt-on LS1.
A M/T ET Drag 26x10.5x15" tire would probably work very well.
Old 11-09-2002, 01:06 PM
EVIL's Avatar
i agree, 26x10 et drag would provide a little better traction than a et street. you could also go with the 27x11.5 hoosier qtp's like me and moose run.
Old 11-09-2002, 02:49 PM
sited12's Avatar
I agree with the above. The manual trans lets you leave hard enough where you need a ET drag instead of the street.
Old 11-09-2002, 03:41 PM
LARRY01Z28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by EVIL:
<strong>i agree, 26x10 et drag would provide a little better traction than a et street. you could also go with the 27x11.5 hoosier qtp's like me and moose run.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do the hoosiers hook real good? I used hardtops, et streets and they felt wesome. but i think there is more traction to be had once i get the 12 bolt. i want to be able to leave the line and cross the 1320 right at redline. but i dont want to do heads and cam yet. thanks alot guys. anybody else got any info?
Old 11-09-2002, 03:45 PM
EVIL's Avatar
moose got a 1.52 on them that day at mir. i got a 1.51 on the spray on them. they seem to work noce if you have the gear for them. moose runs the 4.30's in his car on them, but with 4.10's, you should cross right at 6100-6200 with no problem.
Old 11-09-2002, 03:50 PM
LARRY01Z28's Avatar
EVIL, do i have to run tubes with thos hoosier qtp's?
Old 11-09-2002, 06:23 PM
LARRY01Z28's Avatar
ok,does anyone know if i have to use tubes with the quick time pros?
Old 11-09-2002, 08:13 PM
Frank95z's Avatar
Moose and Evil I just changed to 27x11.5x15 QTP and I like them also. I ran 1.53 shortime and 11.67 with a stockhead stockbottomend Lt1. I run the tires with no tubes. I now have 22 runs on them with a 1.55 average shortime. Frank95z
Old 11-09-2002, 08:51 PM
LARRY01Z28's Avatar
frank95z, thank you for your reply. I think i will go with the QTp's i seen a price of 170.00 for them. ill check around and see if i can get a better deal. thanks alot everybody. if anyone else has anything to add th this thread please do. imnew to the world of actually getting good launches. im a nitto guy. so all the help is appreciated.
Old 11-09-2002, 09:52 PM
EVIL's Avatar
larry, no tubes in mine. check with edge hawk, he got mine for like 155 each plus no shipping.
Old 11-09-2002, 09:56 PM
LARRY01Z28's Avatar
thanks evil. ill get with him.
