Drag Racing Tech
What is your best 60/ft on Nittos with a M6?
Old 11-10-2002, 09:34 PM
AINT SKEERED's Avatar
Default What is your best 60/ft on Nittos with a M6?
Mine is 1.71 at No problem raceway and backed it up at state capital in BatonRouge with a 1.72 on 16 inch Nittos 245/50/16. please be honest,Chad
Old 11-10-2002, 10:54 PM
UnbelievabLS1's Avatar
Default Re: What is your best 60/ft on Nittos with a M6?
1.92! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I'm just too scared to launch any harder on the stock rear w/3.42's! That was with 245/50/16 Nitto's. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 11-10-2002, 11:34 PM
mykdiver's Avatar
Mine was a 1.92 also on my stock rear with stock clutch, I did not want to push it any harder on the stock rear.
Old 11-11-2002, 12:02 AM
RAGEman's Avatar
1.82 with stock 3.42 rear and stock clutch. 1.71 is flyin'! What gear ratio/clutch was that with?
Old 11-11-2002, 12:13 AM
LEO
LEO's Avatar
1.79 with 16" Nittos, stock 3.42 gears @ HRP.
Old 11-11-2002, 04:05 AM
This was done with 4.10 gears in stock 10 bolt with a rearend girdle and 85/140 royal Purple gearoil for extra cushion. Centerforce duel friction clutch. I use to just clean the tires off and pull 1.90's but seen a freind hook hard by doing a big burn out and now so do I. My 60/fts stay in the 1.7's for the most part and dip in the low 1.7's if I get aggressive( 4200 rpm's and dump).Check sig for more on my set up. new best is 11.75 @ 118.49 mph with 1.72 60/ft
<small>[ November 11, 2002, 04:06 AM: Message edited by: AINT SKEERED ]</small>
Old 11-11-2002, 09:23 AM
TATERBUG01's Avatar
1.73 and a 1.77, stock clutch and 3.42s! Running 275/17 BFG DRs. John Force burnouts work <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
But I done for the year, at the limits of the stock drivetrain <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old 11-11-2002, 10:04 AM
dug
dug's Avatar
I got a 1.92 with a 4000 grand launch with stock clutch and 3.42s. They were dead hooking. Had to do a long burnout though.
Old 11-11-2002, 10:36 AM
98TAauto's Avatar
my good friend Larry01Z28 cut a 1.70 or 1.71 I think on nittos.. lead to a 11.7@118 pass stock internally
Old 11-12-2002, 05:50 AM
smokinHawk's Avatar
1.7 rocks
my best is a 1.9 not getting them hot enough i guess.
Old 11-12-2002, 08:26 AM
LS1Tech Co-Founder
Nine Ball's Avatar
1.72 best. back when I was heads/cam/3.73s (11.61 @ 119mph) 3 years ago.
-Tony
Old 11-12-2002, 02:11 PM
LARRY01Z28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong>my good friend Larry01Z28 cut a 1.70 or 1.71 I think on nittos.. lead to a 11.7@118 pass stock internally</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">hey thats me, lol thanks Harold
I got a best of 1.709 11.807 @ 117.03 at VMP
then a 1.748 on a different day i went 11.779 @ 118.90 than wsa at MIR
Hope this helps.
Old 11-13-2002, 05:56 PM
SSilver's Avatar
damn I must suck at launching <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
My best 60' time was a 2.2 on 275/40/17 nittos and thats with a lot of spinning. I've got stock 3.42's with a star stage 3 clutch.
Myabe its because i have a burnt posi and only 1 tire spins <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 11-14-2002, 12:15 AM
LARRY01Z28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSilver:
<strong>damn I must suck at launching <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Myabe its because i have a burnt posi and only 1 tire spins <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">dont say you suck. it just takes alot of pratice. get the posi fixed and then try again.
Old 11-14-2002, 05:43 AM
smokinHawk's Avatar
I still do some 2.3's on my nittos if i dont get it right. Best i found do a burn out, rev and hold to 4k, then drop the clutch, that lets me have 1.9-2.1's
any other ways that are better??
Old 11-14-2002, 06:29 PM
On a good hooking track I run 18 psi in the nittos, and on a not as good track I run 16 psi. It does take a good burnout to work though. I also recommend to go aruond the water and back into it with the rear tires and then roll forward untill you are out of the water to start spinning ,for those that did not know. Chad
Old 11-14-2002, 09:11 PM
Zturd's Avatar
Um NITTO"S SUCK!!!!!!!!!
Nitto 60ft> 1.94
Street tires>1.89
BFG DR,s>1.75 clutch slipping <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
BFG DR's>1.79 no clutch slipping with a bog
3.42 gears
Old 11-14-2002, 10:58 PM
Bad1le's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zturd:
<strong>Um NITTO"S SUCK!!!!!!!!!
Nitto 60ft> 1.94
Street tires>1.89
3.42 gears</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Umm...maybe you just suck at driving?
AJ
Old 11-15-2002, 01:20 AM
LARRY01Z28's Avatar
Nitto 60ft> 1.94
Street tires>1.89
3.42 gears</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">1.70's on nittos for me so i say they dont suck. you just have to know how to launch them. every tire is different. you just need to know how to launch what ever thire you choose.
Old 11-15-2002, 05:49 AM
smokinHawk's Avatar
How do other people launch there nittos??
