Drag Racing Tech
Curious, anyone use the stock fuel tank for balast?
Old 03-30-2005, 12:02 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Lightbulb Curious, anyone use the stock fuel tank for balast?
I'm wondering if anyone installed a smaller fuel cell in the hatch of their f-body, and uses the factory fuel tank to add/remove balast? Just plug up the tank, put a drain valve on it, and use water to fill it in order to add weight. The position over the axle should be ideal for adding weight.
Just curious
Old 03-30-2005, 01:28 PM
I ruin the end of films...
mongse's Avatar
I've seen the stock tank used for all kinds of interesting things. Dividing it in half and hiding a bottle in it was my favorite.
I'm sure you could do it. Same w/ putting it in an old catback muffler.
Old 03-30-2005, 01:52 PM
HotRod68Camaro's Avatar
I dont have 2 tanks on my 68 but iv got such a bad traction problem with my street tires that i make sure i fill the tank up before i race. It does help.
Kyle
Old 03-30-2005, 02:53 PM
93LS1RX7's Avatar
Or you could fill it with sand that way you dont have to worry about the slosh or rust.
Old 03-30-2005, 05:04 PM
squinn's Avatar
Per NHRA/IHRA rule book, No liquid or loose ballast( i.e., water, sandbags, rock, etc.). Myself I need to a over 200 lbs to my car, and looked in to that.
Old 03-30-2005, 05:06 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
We put moonshine in ours cuz that's our bidness how we make da money.
Old 03-30-2005, 07:01 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Coach
Old 03-31-2005, 08:08 AM
93LS1RX7's Avatar
The way I read that rule is no liquids (Safety from dropping on the track) and nothing loose in the drivers compartment/trunk (Safety, they dont want a 30lb sandbag flying through the drivers compartment same as a battery hold down). I dont think sand in the gas tank would violate the letter of that rule or the intent of that rule but that is just my .02
Old 03-31-2005, 09:32 AM
mongse's Avatar
When you painting the rebel flag on the side and the big "01" on the top?
True. I believe the rule applies to ballast INSIDE the car. Filling part of the fuel tank or a rear exhaust section wouldn't be applicable.
Old 03-31-2005, 10:41 AM
DietCoke's Avatar
So ah, zip tying sandbags to your exhaust tips is okay, right?
Old 03-31-2005, 10:58 AM
mongse's Avatar
Sure. I prefer concrete in my bumper. Helps for rear end collisions too.
Old 03-31-2005, 11:54 AM
ou812/z28's Avatar
i have a friend in the NMRA that has a 300 lb rear bumper support/ he took the metal bumper support off and heated it up and melted wheel weights in it and it works he meets min and it hooks like hell.
Old 03-31-2005, 12:06 PM
DietCoke's Avatar
Bet that makes for some good traction
Old 03-31-2005, 02:20 PM
ou812/z28's Avatar
i told him if he ever lost that thing they would have to get some big dudes to get it off the track. i tried to pick it up and could only drag it/
Old 04-02-2005, 08:38 PM
PRAY HRD's Avatar
holy crap!!! lol. with enough power and a light front end, i would think that's nearly enough to lift the front tires at a stop light. now that would be cool!
Dave
