Wolfe bolt-in opinions
Who's running a bolt in wolfe 6 point? I picked one up today for a KILLER deal and i figured id get some feedback before i start tearing the interior out.
How's the fit?
Any little tips/tricks to the install, anything i gotta watch out for?
lastly, the bar isnt a swing out model so the passenger side door bar isnt exactly easily removable. should i bother to use it? are there any downsides to only running it as a 5-point?
thanks for the input.
How's the fit?
mine fit actually really well. pull the carpet back and drill all your holes. then just cut an x in the carpet where it bolts down under the plate and slip the carpet through the plate,bolt it down, then trim the carpet around the tubes.i had mine powder coated after i had it in the car for a year,just too make shure it fit well and i was happy with it, GOOD LUCK!!
Fitment is excellent. Just remember to assemble the whole cage in the interior before you start drilling any holes. I would just use it as a 6 pt, especially if you have t tops, the side bars are pretty low and easy to get in and out of the car. You'll have to remove the plastic surround on the gas cap to feed the nuts on the drivers side. Oh, and say goodbye to your rear speakers if you have them.
Good luck.
Good luck.
I went to a parts store that sells body shop supplies and bought a tube of seam sealer. it applies like caulking. it help give the plates a flat suface and keeps the water from getting trapped on the bottom. I applied it inside and out. that was a year ago. I have the wolfe 5pt with swing outs. fit and finnish was great
