Spohn tq arm???
Spohn tq arm???
Can this thing handle some 6 speed clutch dumps with 60fts in the 1.5x range? I a little worried about the way it bolts to the floor.
Cliff
Cliff
Originally Posted by Cammin BeaSSt
I believe Harlan runs one. If its living up to 8 second passes Im sure it will be fine for pretty much anything.
I wonder if he has re-inforced around the floor pan?
It bolts to the X mbr mounting points which were designed to be structural unlike some of those traction bars that bolt to the trans tunnel sheet metal with like 8 bolts or whatever. I have one and I cant imagine how any bolt in off the shelf could be any beefier.
Harlan has run one that's been exercised well.
I've cut 1.4x with a soft converter and a 3,850lbs car. We'll be looking for harder launches on the new combo when the suspension gets dialed in here in the near future.
Rick
Rick
Tenured Member
The only time you will see any downward force on the mounting bolts is when you are braking. Under severe acceleration the torque arm is actually lifting the car. Put it to the floor side-step the clutch and don't worry about it.
