Smaller radiator question
I would like to cut out the upper radiator support and weld a new upper support out of square tubing. I would also like to cut the lower support and make it level so the radiator would stand up.
First question is would there be enough cooling with a smaller radiator on an all track car?
And has anybody done this? I am installing a PTE-88 and would like some more room.
Are you talking about a drag strip, or a road track? If it's strictly a drag car, of course it will be fine. You could get an electric water pump to cool it off between passes, if it even needed it at all.
I recently moved to a small Griffin. Drag race only. No problems. Keeps the SS at 180 or lower - even in the staging lanes. Turn on the fans (I use only one of the original fans) and keeps in the 170-175 range. No cutting needed. Just measured the size needed to fit inbetween the braces. I'll attach a picture of the engine bay. Really cleaned up the looks of it.
David
David
Originally Posted by redrumss
David what was the size of it and could you post some detailed pictures..???
Both cars look awesome.... BTLFED setup is what I am wanting. Size..???? Price...????
Be Cool Featherweight Scirocco / Pro Stock Style Radiator
Dual 1" Core, 13"x22" $399.99
