Drag Racing Tech
Is This Legal
Old 07-06-2005, 04:43 PM
KAOS's Avatar
Default Is This Legal
kill switch
are these any good
Old 07-06-2005, 06:30 PM
xaon's Avatar
Originally Posted by KAOS
kill switch
are these any good
not legal for NHRA/IHRA due to the removable key.
Old 07-06-2005, 07:46 PM
ChevyGoldfinger's Avatar
kill switch
are these any good
Due to the flimsy plastic taillight panel in our F-Bodies, this Push-Pull switch works extremely well and doesn't put any strain causing cracks in our body work. The heavy twist type switches tend to be too heavy to mount on our back panel without eventually tearing/cracking the body.
This one is from Moroso @ Jegs.
710-74105
Moroso Push/Pull Battery Disconnect Kit | $46.99
Link. . .
http://www.jegs.com/cgi-bin/ncommerc...30&prmenbr=361
If your taillight panel is too lightweight to support a battery disconnect switch, here's the answer! Simply mount your switch inside the rear compartment (on the roll bar tubes, etc.) and exit the extension handle through your rear panel. Kit includes all brackets, swing arm, 18'' long aluminum tube link plus all bushings and fasteners.
Note: You still have to buy the actual switch and heavy gauge wiring. Also the sealed Moroso battery box is needed for NHRA rules when battery is inside the car.
http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361
Jegs sells a wiring kit. You need at least #1 gauge wire.
http://www.jegs.com/cgi-bin/ncommerc...72&prmenbr=361
This 250 amp switch from Flaming River is a good one.
898-FR1003 250 Amp Switch | $59.99
http://www.jegs.com/cgi-bin/ncommerc...54&prmenbr=361
Then another return run of #4 wire back to the alternator. My wiring is run underneath the car. Lot of work and not cheap to put an Optima in the back of an F-body. Nice weight transfer though.
Old 07-06-2005, 08:15 PM
xaon's Avatar
yep. I have the flaming river big switch & lever kit on my car. #1 wire for the main power source, #2 coming from the alternator.
http://www.cepheid.org/~kris/inprogr...4/P1010077.JPG
Old 07-07-2005, 05:18 AM
KAOS's Avatar
can you just not switch the ground. ive noticed that when that ground to the battery is disconected everything shuts down. would this not work and still meet rules/regulations
Old 07-07-2005, 08:27 AM
12secSS's Avatar
You need to cut the alternator as well, just cutting the battery will not kill the engine in case of an emergency. That is why you would want to route it to the positive, I don't think it is possible to kill the alt. by disconnecting the ground ... the alt. body is ground and connected to the engine.
Old 07-07-2005, 08:46 AM
93LS1RX7's Avatar
Yep has to be after the alternator but before the fuse block.
To test and make sure you have it right start the car and while it is running throw the kill switch. If the car stops you are good to go, if not you need to rewire.
Old 07-07-2005, 05:57 PM
KAOS's Avatar
ill try and let you guys know
Old 07-07-2005, 08:39 PM
KAOS's Avatar
no the kill switch has to be visable, cant be under the car like where you can just reach under the body panel, it has to be visable to where you can see it? correct?
Old 07-07-2005, 08:49 PM
Sandmann120's Avatar
Correct, it has to be visable and labeled. Pull/off, that kind of thing.
Old 07-07-2005, 08:52 PM
KAOS's Avatar
well i know what i gotta do then
