Traction Probs..need advice
More or less, I just need someone to tell whether my assumption is right or not. Last night at the track, I was having major traction issues. Car was off by over a tenth on 60', and I could barely stall the damn thing without pushing thru the verter and rear brakes (which are nearly gone and may be part of the problem), and having the car jump forward.
I'm am on 555R's so I'm not doing a John Force burnout, but I am waiting till I see the bastards smoke for a few seconds, and also doing some test launches just to make sure. A few passes, just fine, others....it would spin real bad on each test launch, but I wouldn't go back to do another burnout.
When i roll thru the waterbox, I run the front tires thru also. Some BS brand 245/50/16 radials on 16x8 Salad shooters. My thought is, the fronts are not treading water like they should, and I am just dragging the Nittos thru all that water the fronts are leaving behind...this being the reason the car only spins right after the burnout......altho i have done burnouts the same all season and never had this problem ???
or.....could it be the nittos are about gone.....they still have the 2 outer lines, and the smaller curved lines are barely barely visible. I thought i ran out the last set worse than these still hooking, but i dunno.
now your thoughts...
thanks!
thanks!
I'm bettin the fronts are the problem with the 60's.
First off you DO NOT drive thru the waterbox with radials on! Drive around the water and back up into the box.
And another thing that could be effecting it is the fact that you can't get up on the converter as much as usual.
And last yes the Nittos MAY be worn a bit to far. Just depends. and did u ever change tire pressure?
You shouldn't do test launches. I was told when you do that, you are taking away from the fresh rubber thst you would lay down from the launch. The way I do a burnout is to heat the tires up to a nice smole, then let off the brake and let off the gas after you feel the car hook. Pull straight to the line.
well i race for points in a bracket class and every little thing counts once u leave the line, so i would rather blow the tires away on a test launch, and at least be able to back up and do another burnout if needed, then to blow a race bcuz of tire spin. but thanks for the tip...when i fix the problem, ill give it a try and see if she hooks harder.
