Minitubs=stock tank?
Ok random question here just cause I havent looked under the car to see if it works. But with a minitub does it interfer with the stock tank at all? Cuase once again i still want to use the stock tank
Stock tank will work fine. Becareful when you are cutting around the frame though. The fuel lines run right there. The fill tube will be in the same spot. The tub shouldn't go that far.
Originally Posted by MADMAN
it can be done but its a ton of work.
Does anyone have pics of the drivers side!?! All I hear abou tis hwo hard it is yet no one has posted a single picture of the driver's side. Can anyone help on this one?
