Drag Racing Tech
Jegster T/A & 3" True Duals - Pics
Old 01-17-2006, 06:17 PM
calongo_SS's Avatar
Default Jegster T/A & 3" True Duals - Pics
Obviously the install is not yet completed, but you get the idea. I have about the same clearlance as I did with the stock T/A which is not much. It is closer at the mounting point on the rear end. If I have problems with it hitting, I'll figure something out. I still need to bolt the mounting bracket in place, and adjust the pinion angle, but I think it's going to work out all right.
Opinions?
Thought I'd thow in a pic of the new meats (old street tires vs. new) as well. Think it will hook?
Attached Thumbnails Jegster T/A & 3" True Duals - Pics-dsc00376.jpg   Jegster T/A & 3" True Duals - Pics-dsc00377.jpg   Jegster T/A & 3" True Duals - Pics-dsc00378.jpg   Jegster T/A & 3" True Duals - Pics-dsc00379.jpg   Jegster T/A & 3" True Duals - Pics-dsc00368.jpg
Old 01-17-2006, 06:24 PM
calongo_SS's Avatar
More pics
Also putting 3.5" prostars up front w/ M/T Sportsmans w/ 2.5" studs & .25" spacers - no grinding.
Attached Thumbnails Jegster T/A & 3" True Duals - Pics-dsc00369.jpg   Jegster T/A & 3" True Duals - Pics-dsc00370.jpg   Jegster T/A & 3" True Duals - Pics-dsc00375.jpg   Jegster T/A & 3" True Duals - Pics-dsc00372.jpg
Old 01-17-2006, 09:14 PM
Full-Force's Avatar
Does that torque arm stick out further toward the driver side than the stock one or is it the same?
Its hard to tell from the pictures but it looks like your exhaust goes back too far and is putting it close to te torque arm.
Old 01-17-2006, 10:34 PM
calongo_SS's Avatar
Yeah, it's further to the drivers side. It's pretty close, if it rubs I'll have the exhaust modified.
Old 01-18-2006, 08:05 PM
calongo_SS's Avatar
Just wanted to let everyone know that this install is a major PITA. Basically the entire interior has to come out.
Old 01-20-2006, 04:02 PM
LS1TECH Sponsor
Steve Burger's Avatar
Where did the TA come from? Jegs?
Never Mind I found it.
Old 01-20-2006, 04:25 PM
TS6
TS6's Avatar
All I had to do was pull the console on my LT1 car to install it. Not too bad, hell I did that back when I was new to modding cars.
Old 01-20-2006, 06:32 PM
Gold Z's Avatar
We used the Jegs adjustable torque arm on my son's 99 Camaro. It is a pain to install but with some creative bending we were able to make it work with a set of 3" Lanes true duals and a Moser 9" rearend also. It required quite a bit of grinding and fabricating to get everything to fit properly but we were able to do it. One thing that anyone considering using the Jegs Torque arm should know before they buy one is that it is considerably shorter than a stock torque arm and you will need to make changes to your suspension setup to get everything working in sync. LCA relocation brackets are mandatory.
Old 01-20-2006, 10:46 PM
TS6
TS6's Avatar
I didn't have to do a thing to make it fit my car. What does the TA have to do with LCA brackets?
Old 01-21-2006, 12:24 AM
Gold Z's Avatar
It may be different with a 10 bolt but with a 9" the LCA angle changed to negative. In other words, the front mounts of the LCAs were lower than the rear mounts. This causes wheel hop and loss of traction. Relocation brackets were necessary to get the angle back positive again.
Old 01-21-2006, 01:24 AM
SPEEDYws6's Avatar
Same thing happend with my 9". It wheel hopped so bad it bent the wheel studs on the left side.
Old 01-21-2006, 08:37 AM
calongo_SS's Avatar
I'll have to double check the LCA angle, but it looked ok to me.
I am going to have to change the exhaust on the drivers side a little bit, but it shouldn't take too much.
