Billingsley/AC delete plate and heat?
Somone has pics where they modified the stock heater/ac setup and made it fit.
Cool, any idea who? Hopefully they will see this and post.
Originally Posted by 11SECSS
heres what mine looks like ...but you can cut away some off the inside to make it flush but might not flow air as good IMO
I removed the box from the car and cut away the factory box then made a template out of some thin metal and made it 1/4 longer and folded the edges over and screwed it and sealed it up .....I might take it later in the year and try remodifying it as to take away more weight and only keep the defrost only saw a pic on hear before.....if you want I can email you some pics tommorrow as they are on my other comp at work.
Originally Posted by John_D.
A few pics here. I haven't made the plate yet.
http://frrax.com/rrforum/index.php?act=ST&f=21&t=6589
Im in the process of taking out all of the vents and such for the heat and air. This is basicly what i am down to. I got this pic from one of the above links.
How exactly does the blower speed resistor coil do? Is it possible to get rid of it and still keep the heat?
i read this post twice and i think i'm confused.why wouldn't your heat work if you delete the a/c.my ac was deleted when the cam went in i still have full heat.all they did was disconnect the lines at the firewall and remove the compressor.am i missing something?
I guess what I want to say is there any way you can wire the blower motor, so that it is eather on or off, not variable speeds, and still use the factory ****. I want to keep my heat , but I dont want that red hot blower speed resistor coil setting out in the open.
Pathological Modifier
Ryan K.
That's my pic. I'm not too keen on the coils hanging out either. I'm probably going to relocate them inside the housing.
