Drag Racing Tech
Low Lead 100 Octane?
Old 04-03-2006, 08:54 PM
SLPSS99's Avatar
Default Low Lead 100 Octane?
Hey guys I am going to be installing a TNT Twister Force 2 wet nitrous kit with a 200 shot of Nitrous, I have the fuel system taken care of but have a question on running a higher octane fuel Do I have to run Unleaded Race gas or would I be safe with the Low Lead 100 octane? Also what O2s can take leaded gas?
Dan
Old 04-04-2006, 08:13 AM
SLPSS99's Avatar
Anyone?
Old 04-04-2006, 09:43 AM
LS1TECH Sponsor
Steve Burger's Avatar
I would run VP Fuels C10, Sunoco 104, or get Torco race gas addative.
Old 04-04-2006, 12:30 PM
koolrayz's Avatar
I just bought 15 gal of the vp 109 motorsport unleaded for my stand alone. I have wondered if I could get away with using leaded in the stand alone but figured why bother after finding 109 unleaded.
Old 04-04-2006, 06:40 PM
stevemilz's Avatar
If you want to run 100 octane unleaded look up CAM2. I this in my blower car.
http://www.racegas.com/gt100locals/g...alsmainASP.asp
Old 04-05-2006, 02:13 PM
1BADAIR's Avatar
vp ms103 or ms109
denso o2's are some what lead friendly from what I hear
Old 04-05-2006, 03:19 PM
SLPSS99's Avatar
I found a gas station right by my house that has this gas gas, so I think I will try it.
I should be able to use stock O2 sensors with this gas then? or will I need aftermarket ones.
Old 04-05-2006, 03:26 PM
Navy David SS's Avatar
You'll need to run the Denso O2's. Just my experience, the stockers went out after just a couple of weekends. I ran the Denso's for 2 years without having to change them. -- I run as high as 114 leaded gas.
David
Old 04-05-2006, 03:47 PM
stevemilz's Avatar
Its unleaded. I have stock replacement Bosch o2's
Old 04-05-2006, 04:06 PM
sickss228's Avatar
You'll be fine CAM2 is a 100 octane Sunoco race fuel, I've run it often w/ stock o2's and had zero problems.
Old 04-05-2006, 04:15 PM
stevemilz's Avatar
I stricly run it in my car with a methonal kit, I was just stating I run Bosch o2's (buddy works at Autozone free).
Old 04-05-2006, 04:55 PM
cartekls1's Avatar
have you guys heard of trick 110 leaded? GOOD or BAD? I get a check engine light for slow o2 responce even if i mix it with 93!
Old 04-05-2006, 06:41 PM
stevemilz's Avatar
Whats your reason for running that in your ride?
Old 04-05-2006, 07:02 PM
sickss228's Avatar
Sweet deal man hook it up
