top speed with 4.56's and 28's
i have a 98 z28 with fast 90 90 t rex cam 1 7/8 koooks headers th 350 with a 306 first gear with a 8 inch 5500 verter with a trans brake 12 bolt with a spool and 4.56's with a 28 10.5 15 et drag....the car makes 405 rwhp with a 460 foot pounds tq...car sits at 2832 pounds...this is a cam only car..i shift at 7000 to 7200....do you think i can make it down the 1/4 mile or will i need a taller tire....i juss run 1/8 mile so im juss curious to see if i wanna run the 1/4 if i can make it or not...or will have to go to a taller tire
thanks
thanks
If you hit the rev limit right before the finish, it's not going to hurt the ET much at all, just ride it out! Might hurt the MPH a little, but if you mostly run 1/8 I would not change anything for an occasional 1/4 blast.
Al
Al
