flywheels for ls1+ 350 turbo
it is a very nice piece. i have a stock 98 one on my swap in my car but i just used the tci one on a ls2/th350 swap into a third gen i did for a guy. if i had to do mine all over again i would probally buy the tci one
FYI....Make sure u grind the coating off around the bolt holes. I just had mine come loose and it made some horrible rattling noise under the car this past weekend. It happened after I was messing with the trans brake, but im still kinda pissed about it. The bolts are still tight with blue thread lock, but the coating chipped off around the bolts so it created a gap between the FP and bolts.
Race your car!
You can make a 4l60 flywheel work.. but it's not pretty. Hughes also makes a nice SFI approved one for th400/th350 swaps. ONe thign to rember though, all teh aftermarket flywheels make more noise with teh started then the factory ones do.... nothing that's bad, just something to be aware of.
Hughes one is a relativly inexpensive piece as well. I got mine thru eastside, adn I know it was a good bit cheaper then the TCI one was.
