Drag Racing Tech
Help!!! Traction Sucks!!!
Old 10-18-2006, 01:32 PM
bigdsz's Avatar
Default Help!!! Traction Sucks!!!
I've got MT DR's, anything over around 3,000+ launch makes me bounce off the rev limiter. I'm only putting out about 420 rwhp. The odd thing is that when I dump the clutch at launch the engine torque lifts the drivers side and goes down on the passangers side. Consequently the drivers side leaves a heavy black burn mark, while the passanger side leaves a much lighter colored burn mark. I have a 9" Detroit locker so I know the power is being distributed equally. I have relocation brackets adjusted to the bottom hole. They have completely eliminated my severe wheel hop. Kevin at MT tells me that their DR's shouldn't be used on M6 cars. How about some input as to why my burn marks are so unequal. Thanks.
Old 10-18-2006, 01:48 PM
rocketman442's Avatar
I can just kill my MT DR's at a 3k dump to even if they are warm.
Old 10-18-2006, 02:21 PM
STL2SLO's Avatar
I dont know what to tell you about the unequal "burn marks" But have you checked your pinion angle? I would check that first..
Old 10-18-2006, 02:25 PM
Ericbigmac83's Avatar
What is the deal with the no MT DR's on m6 cars? Ive heard that before but never understood it
Old 10-18-2006, 02:40 PM
mike c.'s Avatar
you have a 9'' rear w/dr's? WHY? get some slicks. i run m&h racemaster cheeter slicks www.intercotire.com i pull the front wheels at 6,500rpm's dead hook to 1.42 60 foot times w/ a 3,700bls m6 car. i've tried m/t et street,drags and hoosiers,nothing hooks for me like the m&h does.
Old 10-18-2006, 03:33 PM
LS1Tech Sponsor
MADMAN's Avatar
LS1Tech 20 Year Member
Put a antiroll on it and a torque arm and she will hook better.
__________________
www.madmanandcoracing.com
225-343-9029
Old 10-18-2006, 07:43 PM
bigdsz's Avatar
The reason I don't have slicks is that I've been waiting for PSJ to convince Centerline there is a market for 15X10's where you don't need to grind the calipers. What pray tell is an "antiroll"??? Thanks
Old 10-18-2006, 07:58 PM
mike c.'s Avatar
i have a bmr antiroll rear sway bar and it helped in the 60 foot,1.48 to a 1.42 and the car does feel stiffer and better just driving around town.
Old 10-19-2006, 02:17 PM
2002blackZ's Avatar
an antiroll is a massive rear sway bar that helps keep your rear level. Sort of the same idea as a large sway bar helps in keeping the car level in a turn. this helps keep both tires planted firmly to the pavement. The spohn one I have seems to work pretty well. Check the sponsor sites and look in the supension/ chassis sections under sway bars.
