Drag Racing Tech
How to drop my 60...
Old 11-25-2006, 12:02 AM
K9Kev's Avatar
Lightbulb How to drop my 60...
HELP
Well, I've had the car out several times to Kennedale here in DFW and, althoughit seems to be running right, tune is good, and making 400 @ the wheels, I can't seem to cut less than a 1.9 60 foot.
I've got 3:73's, a 2800 stall vert, M/T Dr's, an LG Motorsport T/A, weld in SFC's, Adj. LG LCA's, cam, LT's, etc, etc....but nada.
In the 1/8th mile I am the 8.0 king. Runs it every time so....I come for advice. Anyone have some input??
Old 11-25-2006, 12:08 AM
gyrene2003's Avatar
sorry for the off topic, but damn if thats not one of the baddest cop cars ive ever seen!
Old 11-25-2006, 12:13 AM
JPJBC's Avatar
Are you launching off idle or stalling it up?
Old 11-25-2006, 12:17 AM
K9Kev's Avatar
I've tried stalling it up but it's crept over the line once or twice making the little red bulb come on...Ok...I'll dime myself out....driver malfunction....
Old 11-25-2006, 12:22 AM
JPJBC's Avatar
Just try different rpms to launch from, see how much your stall will hold before you start to creep forward and try launching from a few hundred rpms below that. My old st 3500 did best when I launched as high as I could.
Old 11-25-2006, 12:39 AM
K9Kev's Avatar
I'll try that. I also think I need a bigger vert' I only drive the car once in a blue moon now and it see's extremely limited street use at that.
Since I took it out of service w/ the PD, I've been trying to get it to where I can actually push the button on the NX systems but, I would like to see if I can get the damn thing to run decent N/A.
Old 11-25-2006, 09:08 AM
gator's 99TA's Avatar
2800 is such a tiny converter. i have always felt it was easier to launch a looser converter than a tighter one. you have more play with it.
no substitute for a good drag radial and a good converter. you seem like you have a good tire in there. what tire psi? big or small burnout? ar eyou spinning or hooking?
practice practice. getting a bigger converter in there will help imo. no reason that car doesnt go 1.6-1.7 60' on the nitrous
Old 11-25-2006, 12:59 PM
K9Kev's Avatar
Originally Posted by gator's 99TA
what tire psi? big or small burnout? r you spinning or hooking?
Around 20 lbs. Mid sized burnout...till it starts to grab, then a little dry hop, still spins abit when comming out.
Old 11-25-2006, 03:57 PM
cjg454ss's Avatar
im having thwe same problem. 3600, 342 and auto. cant 60 foot better than a 2.1 with et streets. car has 400+ whp and does not spin. im thinging 373 or maybe 410 rear.
Old 11-25-2006, 04:09 PM
sickss228's Avatar
What are you guys setting your pinion angle at? Not sure if there is much difference between auto or M6 but I've found -2.5 to work best for me so far, that could be a good starting point.
Old 11-25-2006, 06:40 PM
AINT SKEERED's Avatar
Kev, I dont recommend that dry hop after the burnout. It actually takes the heat out of the tires. Do a little burnout but come out spinning at half throttle untill it starts to bog and make the back end squat. Then pull up and stage. M/t dont seem to like a big burnout from what I have found.
Old 11-25-2006, 07:22 PM
s346k's Avatar
get yourself some m/t et street DRAG RADIALS and STOCK 16" snowflake rims (they're cheap and the lightest of the stock 16" wheels). drop tire pressure to 14 psi. do a HEALTHY burnout, then proceed straight to the line. tq the car up to ~1,500 then flash it off the line when you see green.
i would highly suggest a 4k+ stall speed. i went 4k and wish i had gone larger. i managed consistent 1.62 - 1.64 60' in my full weight bolt-on z28 with 373 gears and 255/50/16 tires mounted on stock snowflake rims.
Old 11-25-2006, 09:12 PM
JUICED96Z
Guest
Posts: n/a
Your stall DOES sound to small, My full bolt-on LT1 car with 4.10's is about to have a 3200 stall put in.
Don't just go with a stall that someone recomends, do your homework and then go from there.
If I listened to everyone I would have a 3800-4k stall and I don't need it.
With just having the cam and all I bet most shops will tell you a 3800 or so.
Keep this in mind, there are a lot of 9 second cars out there with under a 4k stall.
There is some in the 8's with a 4k....
You want your stall to match your powerband. If you start making power at say 3000 rpm you don't want the car to stall at say 4200. See what I am saying?
I was going to go with a 2800 stall but after asking around found out that with my 4.10's my 3200 stall will act just like a 2800 but the car will run like one with a 3200 stall.
Keep in mind my car is a stock internals car.
Old 11-25-2006, 09:26 PM
In his post he said that he had m/t drag radials
Old 11-26-2006, 07:15 PM
K9Kev's Avatar
Ok, a newbie type question but...How do I figure the pinion angle and then do the reset??
Old 11-27-2006, 07:50 AM
You will need an angle guage and a flat ground or lift that picks up by the wheels. check the angle by the front of the pinion yoke to see what angle it has in relation to the ground. This is Madmans way he checked and set mine at No Problem one year at Thunder shootout. set at -2.5
Old 11-27-2006, 10:37 AM
K9Kev's Avatar
Thanks...I apprecaite it. Now...someone got a 3800 stall they wanna sell???
