Is it possible to run stock rear brake lines to manual mstr cyl?
I have a strange master cylinder from billingsley racing with the built in line lock and my intention was to cut the stock rear brake line at the frame, flare the line with a union and run it straight up to the master cylinder....... problem is is that it seems the rear brake lines are metric..... my master cylinder uses 3/8" line...... I know Brady Mcnew's car used teh stock rears but I can't seem to figure out how the hell to flare the line OR how to get a union that will connect to one side metric and one side standard..... There are pictures of this setup of Teamprickracing.com but I can't for the life of me figure out exactly what parts I need....... the flare took I have won't flare the rear line without pushing it right out of the flare block.....
HELP!!!!!!! TIA.....
included a pic of brady's setup... the line going to the rear is the line i'm talking about.... unless that line was custom run (it does look pretty clean) then that "union" fitting between the two is what I need..... but i still don't or can't figure out how the hell to flare the line.....
maybe I need a metric flare tool??? Do they even make one????
That "union" looks like a compression fitting to me...The lines would be cut square. No flaring needed. When you slide the fitting on the lines and tighten it, it will compress the lines.
Cool.... So do I need a metric compression fitting at the stock rear line side???? and then on the other side just a normal standard flare fitting????
The guy at the autoparts store did mention a compression fitting but said I might have an issue getting it to seal... you guys didn't have any issues with the brake line leaking at all at that fitting???? If not i'll go down tommorrow and buy me a fitting...
thanks for the help...
You can flare a metric line using a 3/16" flaring tool.
If you use the full length on the depth gauge the flare will come out a little large, and may not want to bottom out in the fitting all the way.
If you set it just a little short, the flare will turn out smaller (and straighter).
SJM uses some sort of SAE size flare fitting on the metric line... He sells the tool with his abs delete kit, the tool is modified slightly to get a tighter clamp on the line.
I had to flare a 'T' fitting to the single line coming from the master as my car had TCS originally... Whatever type/size of flare fitting it was I dont know, wasnt your average straight flare, but it worked well whatever it was. No leaks at all.
Id contact SJM (Sponsor) and see if he'll shed some light on what he used to adapt the stock metric line to his SAE sized line.
Originally Posted by Old Geezer
smoking a controlled substance. Using a compression fitting on a brake line, is a good start toward winning the Darwin award.
SJM is a sponsor on this site?????? Cause if I can use a standard flare tool I'll buy the thing right now.....
Cause I'd rather use a standard flare fitting than a compression fitting..... Autoparts guy said if I did use a compression fitting it's hella dangerous.....
I kinda wanna have brakes... thanks for the help in this guys.... looks like i'll be calling SJM.....
FWIW, Technically, both are compression style...the one pictured above is a ferrule style which should not be used as others indicated. I heard your message this morning and returned the call but you were unavailable.
Our website phone number has not been updated from our recent move of the shop. The old number is still ported, the new number is 724 478 5580
There is such thing as a metric flare tool. I tried the same thing as you with a standad one. It would push the line out of the block. Get the metric flare tool and a standard nut. Put it all together and it works perfectly.
Cool. Thanks guys for the info.... Steve I returned the call but I think you were out. I know you're shutdown for the holidays so i'll give you a call when the holidays are over and i'll place an order for what you've got....
