Bigger Is Better
Bigger Is Better
Here's the deal. I have a set of 15x10 w/ 5" backspacing Bogarts. I have a 98 turbo formula. We will be cutting the bumpstops off, beating the wheel wells, rolling fenders, and whatever is necessary. I have a Moser 12 bolt. Not narrowed. BMR adj. LCAs.
What is the BIGGEST slick I can fit on there? Height and width wise..
Or MT ET streets??
Will a 30" fit?
How wide can I go?
Or MT ET streets??
Will a 30" fit?
How wide can I go?
Are you gonna cut the rear portion of the fender? It will be necessary with a 29in and up, possibly a 28in too (unless you're skillllled).
You might want to look into mini-tubbing and narrowing..
9-Second Club
Or MT ET streets??
Will a 30" fit?
How wide can I go?
Or MT ET streets??
Will a 30" fit?
How wide can I go?
LS1Tech Co-Founder
Pic here is 28W + 15x9.75 Bogart with ~ 7.5 backspacing. Barely any of the outer fender was cut:
http://psj.ls1tech.com/gallery/main....&g2_itemId=238
that looks good. I just want to go ahead and put tires on the rims, so we can see what we're working with atleast. But I don't want to get tires on there that are going to be too big..
What brand are yours PSJ? and what is the difference on a 28W.. compared to a 28
Don't mind looking like a mexican gangsta.. If it's a fast mexican gansta.. How do I measure the backspacing on my rims?
you can measure the depth of the front or the back of the wheel.. if you measure the front just subtract it from the overall width of the wheel and you get the backspacing...
that kinda sounds confusing.. lol
my friend has 15 x 10 prostars with 7.5 in backspacing and runs 325/50/15's without a narrowed rear. bumpstop is shaved and some tapping from a BFH was all that was needed. An adjustable panhard bar will help to center things out.
I went ahead w/ some 29x11 Hoosiers today. I guess we'll just have to make them fit!
So.. exactly what am I going to have to cut to get these to fit? I already cut the bump stops and beat the wheel wells
Pretty much cut all the way until you can see coil springs on each side and cut and hammer away at the front of th efender also... might have to bust out a plasma cutter.....
You should be ok on the inside fender with 5" backspacing, the the fender of the car that will give you the trouble, I cant see you fitting that tire without jacking the rear up, or cutting the fenders, I had some 15x8.5 with 5" BS and they stuck out about a inch.
Good luck, pm me if you wanna sell those bogarts and they are Welded RT,s.
